SVS Setup ????'s
Herdfan
Herdfan Posts: 13
I just hooked up my new SVS PB2-ISD sub. (Man its big.) Anyway, I need some advice on how to setup my AVR for this new monster.
You can see my sig for my system. Do I really want to set the RTi10's as small? Any ideas for xover settings: 60 or 80?
Anything else I am leaving out, or plain haven't thought of?
Thanks.
Mains - Rti10's
Center - CSi5
Sides - FXi5's
SVS PB2-ISD
AVR - Denon AVR 3806
HDTV - Hitachi 57S500
Denon DVD-2910
DirecTV HR10-250 (63 hours HD)
DirecTV R10 (207 hours)
Post edited by Herdfan on
  • Early B.
    Early B. Posts: 7,900
    edited August 2004
    I have a PB1 and RTi10's up front. I have the fronts set to LARGE and the crossover for the rest of the speakers at 80 Hz. I also set the receiver's sub volume at 2 or 3 decibels higher than the rest of the speakers.
    Placement should be your main concern, although with such a big box, you may be limited.
    "God grooves with tubes."
  • faster100
    faster100 Posts: 6,124
    edited August 2004
    Although it is somewhat of a waste of rti10's to run small.. if you intended on big bass from the svs, why not send all the bass material to the svs? I would set them to small when watching movies and maybe switch to large (if you want) for music.... IMO when you buy a large SVS it's because you want alot of clean clear bass... when set to large, some of that doesnt make it to the sub.. But its all relative in the way it sound best to you and in your room... Good luck and congrats on the new Sub!! :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    With the Denon AVR 2805 - you should set to small. You have an awesome sub, so let it do its job.
    Congrats on the SVS and have fun. Calibrate - Calibrate!!!!!
