Parasound preamps
I really like my Parasound amp. For me thus far they have lived up to their reputation and a lot of their gear is in the modest price range so I'm thinking one of their preamps may be our next step over the summere in the 2 channel room. Has anybody used the P5, P3 and the 2100 to offer an opinion of how different they sound from each other using CD and turntable as the source?
Yep, my name really is Bob.
Parasound HCA1500, Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Oppo BDP93, "upgraded" Polk SDA 2B.
  • oldrockeroldrocker Posts: 2,081
    I run a 2100 with a 2250. Not sure on the difference as I'm only doing Cd's and reel to reel, no vinyl here yet. Both were my first better quality gear and I'm very happy with them. I only wish the 2100 had a volume dial with a light in it. I cut a tiny piece of reflective tape and put on the dial.
  • UpstatemaxUpstatemax Posts: 2,271
    I just got my P5 hooked up to my 1500A and thus far, it is sweet!
    Living room:
    Samsung PN50B860 50" Plasma : XBOX One : Roku Ultra : Oppo UDP-203 : Pioneer Elite SC-87 : APC H15 : Focal 806V mains : Focal 806V Surrounds : SVS SB2000 : SVS SB12-NSD
    2Ch:
    Sonus Faber Venere S : Parasound HCA 1500A : Oppo UDP-205 : Furman Elite 15 DM i : Sony XBR 55X810C Monitor :
  • tratlifftratliff Posts: 724
    I used a P3 for about 18 months and then moved to a P5. From my experience the P5 is smoother, more accurate and provides more detail. The P3 was good but the P5 was a step up and it should be for the price difference. The one dislike I had for the P3 was the digital volume control. I never could get a good feel for it.
    Legacy Focus SE, 2 REL Carbon Limited, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Marantz SA-14s1, Oppo BDP-105, Technics RS-1500, Furman Elite 15PFi, Douglas Connection (Furutech) Alpha Interconnects, Douglas Connection (Furutech) Alpha Speaker Cables, Pangea Power Cables
    Theater
    Yamaha RX-Z9, Legacy Focus SE (same as 2 Channel system), Def Tech C/L/R 2500, Def Tech BP-2X, Def Tech Pro-Monitors, Vizio M-75
    Office
    Teac NP-H750, Parasound Ztuner, Audio Engine P4N, Grado SR80, Grado iGrado, Audio-Technica ATH-M50, PC running High Rez files
    Living Room
    Yamaha YSP-4100 digital sound projector, Sharp Aquos 60"
    Bed Room
    Yamaha YSP-5100 digital sound projector, Sharp Aquos 70"
  • Polkie2009Polkie2009 Posts: 3,836
    Just checking out the P5 in the new AA issue that came the other day. :)
  • Mikey081057Mikey081057 Posts: 6,104
    edited April 2015
    I have a P5 attached to an A21...Very nice combination... Totally quiet and delivers my SDA's to audio heaven... I am sure I can spend a lot more to equal or marginally improve the sound. The P5 has an ok DAC and Phono Pre and has a nice sub controls as well as a HT bypass. All the inputs and outputs you need as well... The A21 is a steal BTW at it's price point. he phono stage equals or betters any $299- $300 phono stage and eliminates a set of interconnects. My Marantz SA8004 SACD player sounds great and also serves as my DAC in my rig and also is a great bang for the buck... Very solid build quality
    The phono stage equals or betters any $299- $300 phono stage and eliminates a set of interconnects. My Marantz SA8004 SACD player sounds great and also serves as my DAC in my rig and also is a great bang for the buck...
    I had a 2100 and sold it to buy my P5.. the 2100 is nice in it;s price range but doesn't hang with the P5
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
    Patio Polk Atrium 8's | Yamaha R-N303BL |
    Office Bluesound Node | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Chromecast Audio | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | 2 Parasound A23's | Marantz 2252B
  • BetaBeta Posts: 260
    I've owned the P 3, JC 2 (sold) and now have the P 5. The JC 2 outperforms the P 3 and P 5 by a fairly significant margin.
    I recently purchased the P5 to use as a temporary piece while my main preamp is being serviced. I've been running it for about 5 weeks. My initial impression was not favorable, but that changed significantly over time. Either my ears adjusted, or it burned in. I'm really enjoying the P 5 now. I'm running it through a quality tube buffer before going to my amp. I'm usually a proponent of having the shortest signal path possible. However, for me, adding the buffer really had a positive impact. I run a digital source through the P 5's DAC and it sounds quite good to me. I don't do vinyl or CDs, so I can't comment there.
    IMHO the P5 is an excellent preamp at it's price point. Given all it has to offer, DAC, phono, HT etc., its really a great value.
    My two cents for what they are worth.
    These are some wonderful, honest reviews guys, looks like the P5 has a lot going for it and it's not priced so high that most polkies can only dream about ever owning one.
  • DSkipDSkip Posts: 15,564
    edited April 2015
    Beta wrote: »
    Thanks for the great input. I'd like to hear the JC line one day and see what it really has to offer. My sentiments are spot on with yours regarding the P5 - great unit given all it offers, but I do feel if you don't need the bells and whistles, there are better ones at that price point.
    I've heard the P3 and P5 and both were nice, but I prefer my Shuguang over the two from a purely SQ position. I think the P3 is a decent value on the used market, and the P5 is unlike any other 2 channel pre I've seen at the price - a great product that has no peers in its class IMO.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • muncybobmuncybob Posts: 2,009
    OK, since I'm the OP I give myself permission to hijack this thread...anybody know anything about the LINN Kolektor preamp? I've read where for this to sound decent you need a VERY good source?
    I haven't heard anything from Linn that floats my boat. That said, ymmv.
    audiothesis.com/
    Cabling: Wireworld
Howdy, Stranger!
