SVS PB13-Ultra?
  • Pinktulip7
    Pinktulip7 Posts: 249
    thx for all the suggestion.
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • dpowell
    dpowell Posts: 3,055
    Let us know what you decide. Either direction will be a nice upgrade for you. :smiley:
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • Pinktulip7
    I am hesitating because if SVS PB15-Ultra coming anytime soon!!!!!!!!
  • WLDock
    WLDock Posts: 3,073
    edited April 2015
    Pinktulip7 wrote: »
    On one hand you see duals as complicated and too much for your small room. On the other hand now you want to wait for the PB15" Ultra for the said small room? Now that speaker will for sure be in the $3000-$3500 price range. Now you are getting into the Seaton Submersive, JTR Audio Captivator range.
    I'm confused...What exactly are you looking for in your small room?
    Dude, for $2500 bucks you could put a couple of the sealed XS15se in that room and a new AVR-4520CI AVR w/ Audyssey Multi EQ32 & Sub EQ HT. Would have the tightness and depth for stereo bass(Music!) and movies with the output to knock your socks off given the room size. Not to mention room correction designed for TWO subs.
    But hey....if the $3K+ SVS 15"-16" or whatever size it turns out to be, is what you are after, then go for it...its the only way you will know.
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
  • Pinktulip7
    WLDock wrote: »
    Pinktulip7 wrote: »
    I will get the PB13-Utra for now on, any receiver you recommend with Dolby Atmos?
  • WLDock
    WLDock Posts: 3,073
    I'm currently on the Onkyo bandwagon but have no plans to go Atmos. I've yet to hear it but hope to find a local theater that has it. Will like to hear what its all about.
  • dpowell
    Atmos is quite enveloping in the theater. I do have plans to move to Atmos in the future but I would like to see a couple of generations of receivers come out before I buy in to the technology. I'll let others be on the bleeding edge and help work out the bugs. :wink:
    I like the Pioneer Elite receivers but now that I have dual subs, I won't buy a receiver unless it has Audyssey Multi EQ32 & Sub EQ HT.
  • mikeyb128
    mikeyb128 Posts: 2,885
    The new pioneer 80 series elite receivers now have sub calibration!
    2 channel:
    Theater:
  • dpowell
    That is excellent news!
  • Pinktulip7
    What is Parametric Eq in the back of the Sub? Do I have to change any setting there?
  • mikeyb128
    2 channel:
    Theater:
  • Pinktulip7
    It's not simple at all!!!
    EndersShadow Posts: 17,542
    Pinktulip7 wrote: »
    You dont "have" to do anything with it. If your not familiar with how to measure the response of your room (or don't have equipment to do so), I'd leave it alone.
    Its not simple as you said. Its worth it if you know you need to boost a certain frequency range due to a dip in SPL, but without really understanding what its for, your likely to do more harm that good with it.
  • Pinktulip7
    Pinktulip7 wrote: »
    Cool
