The Mother And Father Of All Amps!!!
Do they finance? hahaha YEAH RIGHT!Originally posted by gmorris
$25,000 per pair. Chump change...
*Bank* "So you're looking for a hefty sized loan... what's this going to be used for?
*Me* "To buy a pair of amplifiers...
*Bank* *CLICK!!!*Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Originally posted by scottvamp
MRA: Master Reference Amplifier. This 600lbs monaural amplifier will give you about 1000watts RMS 8 ohm pure class A. The MRA doubble down to 0,5 ohm and give you 16000watts of clean power. With its 16000VA power suppley and 280 Bipolar transistors it will drive anything. Probably even drive the smaller krells in the third picture. And its as huge as an ordinary living room table.
To put it in perspective, a 15000VA power distribution transformer can power several medium-sized houses without too much trouble.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Originally posted by tryrrthg
According to Stereophile :rolleyes: this is the best amplifier EVER!
The Halcro dm58 monoblock
It looks like those electro-air filters to me. :rolleyes:
Wes
Not really...your typical newish home with 200A service is 24,000VA/24kVA. Still a helluva lot of juice! -
Wel, it depends on if the homes are total electric, how far away from the pot they are (for flicker and voltage drop) and how you figure the diversity factor. I had in mind for a medium-sized house right around 1500sq ft. We at the power company size them for the actual load, not necesarily the service size.
Here is a suitable CD transport to go with it.
http://cls.audiogon.com/cgi-bin/cls.pl?dgtltran&1097674674
Or my new Tosh your modding....;)Originally posted by madmax
madmax -
Legendary air bearing transport.... do we need air bearings for a CD playerHere is a suitable CD transport to go with it.
http://cls.audiogon.com/cgi-bin/cls...tran&1097674674
madmax
-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Does a exotic sports car really need a V12.............;)
You may be surprised how close they would sound to each other.
But, no, I am using the standard bearings and not replacing your drive with an air bearing. I could spray it with an air compressor before I close it up though.
(If I ever get the freakin capacitors.)
Back to the topic at hand, take a look at this display......droolPolitical Correctness'.........defined
President of Club Polk -
A close up....Political Correctness'.........defined
They look pretty small.
SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
