Crossover Plate Question
boston1450
My spare 2b's havent been used in awhile & last time i moved them to store i noticed something loose. I opened it up & behold the crossover plate (if thats what its called) came undone. I tried to figure how it goes. So i opened up the other speaker & tried to position it the same & it didnt seem to work. The plastic pins didnt seem to line up. Then i played around with it & it fit at a angle. I want to make sure its right before i mount it back in place. I will post picture. Thanks
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
The good one
Randy-Maine
by David WMG
The angled one
Randy-Maine
by David WMG
^^^^^ this one came totally off & appears to be seated right. I think. Maybe the base turned ???????Randy-Maine
by David WMG
Dumb A$$ i am. Yes it turned & i positioned it back. Sorry for the screw up. Is it ok to just use power grab & mount it backRandy-Maine
by David WMG
While in there i glued magnets & stapled fill back up as it slid down quite a ways on one & did the other to prevent it. Fun project
Randy-Maine
by David WMG
The crossover board is mounted to the spool inductor with 4 nylon standoffs. The spool inductor will spin if the hex-head cap screw is loose. Get your Allen wrenches, square up the crossover, and tighten the cap screw from the rear side of the speaker.
DO NOT GLUE THE SPOOL INDUCTOR!Home Theater/2 Channel:
dhsspeakerservice.com/ -
You are correct. I screwed it back snug from rear outside & held base. It was loose. I tightened both up. Waiting for drivers to be put back in place. Looks good otherwiseRandy-Maine
by David WMG
Hey those look stock have you changed anything?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
No i havent. Bone stock
Randy-Maine
by David WMG
