Crossover Plate Question
My spare 2b's havent been used in awhile & last time i moved them to store i noticed something loose. I opened it up & behold the crossover plate (if thats what its called) came undone. I tried to figure how it goes. So i opened up the other speaker & tried to position it the same & it didnt seem to work. The plastic pins didnt seem to line up. Then i played around with it & it fit at a angle. I want to make sure its right before i mount it back in place. I will post picture. Thanks
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
