Wireless DAC
Mikey081057
I want to be able to play music from my android phone/tablet to a wireless (not BT) dac to a pair of out door speakers... I use my media server, tidal etc... What are some quality/good value products for me to consider?
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Teac....
Also, John just put up a Pioneer networking player that has a dac built in for a tad over 3 bones. Would work nicely with your phone.Post edited by tonyb onHT SYSTEM-
lsi 9's -
Anybody seen the Bluesound NODE?My New Year's resolution is 3840 × 2160
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
A much cheaper/simpler alternative that will use any dac with an optical input or use the Wolfson built in. I have been using mine with jriver for the last three weeks. Sounds great, I actually prefer the sound via its analog out than the optical. http://www.amazon.com/dp/B00M5EVR6U/ref=sr_ph?ie=UTF8&qid=1426891589&sr=1&keywords=hapurs+wifiOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
I was also looking at the Audioengine B1.. more expensive...I like their quality
This will be for my outdoor pool rig. I have a pair of Polk Atrium * SDI's that I snagged at F&F and will be setting up that rig this weekend...Sunny & in the 80's water temp 88... Ahhhhh summer... no wait it just turned spring....My New Year's resolution is 3840 × 2160
So I snagged an Audioengine B1 off amazon to try... seems to do the trick... has a good BT range that I might never come close to exceeding... paired up real simple and playing Tidal audio right now... thru my little tube Qinpu amp and audioengine P 4's... I'm going to hook up the Atrium 8's once I figure out placement... and it cools down.... It is hot here..My New Year's resolution is 3840 × 2160
So I hooked the Audioengine B1 to my Marantz AV7701 analog CD input... then took a line level out to the little Qinpu A2 tube amp on Zone 2 of the AV7701 and connected my now mounted Atrium 8's and BAMMMM.. outdoor audio.. very nice indeed. All selectable and controllable via my android phone using the Tidal and Marantz Apps and can play multiple zones at the same time..
If you end up hating that setup try a Sonos connect.
Hows Tidal? I hear they are having skipping and disconnects. Any truth to that?
B&W CM9Classé Sigma -
Works great... Tidal is working fine now....My New Year's resolution is 3840 × 2160
