I-Sonic ES2 Top Buttons not working after firmware update
cardman
cardman Posts: 1
edited May 2011 in Troubleshooting
Hi, I have a Polk Audio I-Sonic ES2 System in which I recently received a thumb drive to update the firmware. I updated just how the instructions stated and saw the Successful installation message. Now several of the top buttons on the system do not work including the power button and time set. I can still power on the unit if I use the remote.
I believe this may have something to do with the firmware update. I would appreciate any suggestions or advice to possibly fix this. If there is a way to reset the system let me know as I have tryed unpluging for a little while but still didnt correct.
Thanks for your time! Dan
Post edited by cardman on
  • TwinCities
    TwinCities Posts: 1
    edited November 2010
    I have the same issue, the top control buttons stopped working after firmware update. Customer Service response is to pack up the radio and ship it in for repair estimate. Since it was caused by firmware update does anyone have a solution they have found, any way to uninstall update?
    For those considering the update to firmware update 1.35, I would advise against based on my experience.
  • KilgoreSalmon
    KilgoreSalmon Posts: 1
    edited January 2011
    Same problem. Updated the firmware, top buttons stopped working.
    I have e-mailed polk a number of times trying to get previous firmware e-mailed to me but they have stopped responding.
    Anyone find a solution? Anyone have a copy of the earlier firmware?
    Thanks!
    F1nut Posts: 51,820
    edited January 2011
    CALL, do not email, Polk Customer Service on Monday.
  • JohnBoi
    JohnBoi Posts: 1
    edited May 2011
    I have not yet updated my firmware and I have the same problem! The top control buttons stopped working.
    This radio was very expensive. The lesson that I learned the hard way here is that I will absolutely never again consider purchasing any Polk products.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    All it takes is a phone call to get you on the way to being fixed. Problems happen, failures occur but Polk CS is second to none when it comes to support.
  • Buttons on the top are not working, not even one is working. I never updated thefirmware, it isthe original purchase from polk.com. How do I fix this ? Has anyone found a solution?i tried holding down power and source but nothing.. Any help appreciated.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Welcome to Polk's forum. The best thing to do would be to contact Kim.Jasper@soundunited.com or via telephone at: 1-800-377-7655 extension 5208.
    Regards, Ken
