In-wall cables / Odd question because of them.
grimmace19
So as my basement finishing kicks into full gear, I'm left with the option of putting all my gear in the back enclosed in a closet for a clean look. Or, shelling out the cash to buy a nice stand that goes up front (salamander @ 2k) for all of my gear. I'm leaning towards putting everything in the back as it's a much cleaner look and cheaper than buying a stand for everything. Because of this, I have about a 30ft run of in wall speaker cable that will need to be run to the front.
I'm open to suggestions as far as what in-wall cable to use, and opening it up to what might be a silly question and turn into you rabid beasts for a cable debate.
Would I be an idiot to run in-wall cable to a banana jack plug on the wall, and use my MIT cables from there to the speakers?
It seems like it's somewhat pointless as the route from the amp to the banana jack would be tainted compared to cables straight from the amp... but again, it brings up the same argument of how a power cable makes any sense if the line running from the source to the outlet isn't high-end. Has anyone tried this? Any tests? It's been tough to research, but the thought of selling off my MITs to opt for a 10 or 12 gauge in-wall for better speakers doesn't necessarily sit right.
http://www.bluejeanscable.com/store/speaker/index.htm
I used the BJC Ten White with good results in my old house. I hope the new owner appreciates the good good cabling I provided
What MIT's do you have?Things work out best for those who make the best of the way things work out.-John Wooden -
I'd say go to the jacks and use the MIT's. You already have them anyway. Plus having the jacks allows for future upgrades in cabling if you so desire. Put quality jacks though in there.HT SYSTEM-
lsi 9's -
All of the Furez speaker cable we have is rated for in wall use. It's a very good OFHC copper cable. We give Club Polk members a 10% discount too. http://douglasconnection.com/Raw-Speaker-Cable_c33.htmSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
