DSW550wi on but no sound
Kalito
I loved the DSW550wi I got a second one to make use of the Sony STR-DN1060 7.2Ch configuration. However, two months or so into this acquisition I have noticed the following issue I need guidance on:
Any ideas?
- The SW has stopped working i.e the LED does not turn on and I do not hear the sub
- It was originally set to Auto and I have also tried the swith on On
- The LED at the back is green
- Nothing has changed in the way the sub is connected. I have also tried swapping them arund to eliminate a potential cable issue, the older sub works just fine on either connection.
- When I switch off the sub using the back switch it takes approx 10sec for the rear green LED to go off and when it does there is a thud sound from the sub
Any ideas?
Polkaudio TL350 satellites
Polkaudio OWM3 satellites for front high
Polkaudio DSWpro550wi subwoofers (x2)
Sony SRT-DN1050 Receiver
Sony KLD-50R550A LCD TV
DSTV Explora HDPVR
PS4
DSTV Explora HDPVR
PS4
Sounds like the classic plate amp meltdown. I have no experience with Polk subs, but I had that happen with and Energy sub and that is what it was...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Hello,
Contact Polk's CS guys at 1-800-377-7655 or via email to polkcs@polkaudio.com have the serial number and date and place of purchase handy when you call or include in the email.
Regards, Ken -
Thanks will do thatPolkaudio TL350 satellites
DSTV Explora HDPVR
PS4 -
Not that this has anything to do with your problem at all but I have the same sub. for like a year I couldn't figure out why I would have to reset it every day because the bass just would go away.
Then one day I realized that the up button on my tv remote control must have use the same signal as the volume down button on the sub. So I tuned the sub in and stuck a piece of tape over the remote sensor on the sub and its been great ever since.
