Should i buy these SDA-2A?
The magnets should be glued ASAP. If you've got the drivers out, do the Dynamat and the Loctite at the same time. Do not use Mortite or any other rope caulk. Use Armaflex/Armacell Foam tape. Roll it out, cut it length-wise in 3/8" strips for the woofers, and 1/2" strips for the PRs.Makes sense, thanks for the answer. So it sounds like there's no urgency to do that mod.
This week end the wife is out of town, so i'm going to do a first easy set of mods during that time.
So far I'm thinking:
fix the cabinet and cloth,
dynamat the MW and PR,
mortite the drivers,
put spikes,
Enjoy some good tunes. ;-)
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks, I checked and I can get that from a home depot not too far away. I'll try to swing there tomorrow. This way I'll do dynamat/Loctite/Armaflex then.
Last night I finished filling all the holes in the cabinets and spent some time sanding. Today I received some cherry wood contact paper and did a quick test. I definitely like it better than the original (especially since the 2 speakers had different stains...)
Oh and here's my ghetto IC for now: it's very high end!!! lol
Main System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Receiver: Pioneer VSX-1121k
Amp: Carver AV 705x
TV: Samsung LN52A650
Media Player: Chromecast/Boxee Box
BD Player: Sony BDP-S470
Consoles: Xbox360, Wii U -
Have fun with your project and you will be rewarded after your done!
and remember the Locitite Power grab for your driver magnets, it goes on like white elmers but dries clear and is so easy to use! I have some monitor 10's & CRS+'s and love them.
I let Dave (wessmassguy) do all my crossover work
I had fun doing the Dynamat Xtreme and hurricane nuts etc to them. 2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Only finished 1 speaker cabinet last night. This is way more time consuming than i thought. I also finished modding my Sony MDR1R with Dynamat.
I'm having a lot of fun doing all this.
Main System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Amp: Carver AV 705x
Looks like it came out very nice.
Nice job on the vinyl.Home Theater/2 Channel:
