Bought an Oppo 981 for $15!
PolkieMan
PolkieMan Posts: 2,446
I got what I think was a good deal at Salvation Army a Oppo 981-HD with remote for $15. Seems like it will play almost everything I can stick in it except for Blu-Ray. 4pvbuyahlfss.jpg
  • Inspector 24
    Inspector 24 Posts: 1,308
    Good find!
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • teekay0007
    teekay0007 Posts: 2,289
    Well done, PolkieMan! Nowadays, in most cases, you can't even find a working remote control for $15. You found one and it just so happened to have an Oppo come along with it.
    And you say nothing ever shows up at a bargain price in Pearland!
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Nice score. I have one and it just keeps ticking...
  • PolkieMan
    It really does 1080p even plays DVD Audio pretty next for cheap :-)
  • skrol
    skrol Posts: 3,442
    edited March 2015
    That is a great find. I had one that I picked up from Good Will for $15 too. It had nice sound while it worked. These units seem to have an issue with power supply boards going bad. You will know it if your power light glows purple and the display is goofed up. Mine has a fried area on the board and a bulged cap. I contacted Oppo about purchasing a new board but they said that I can buy the extended warranty for $50 and they will fix it.
    By the way, I have a pair of Koss Pro/4X Plus headphones just like yours. Do you have a source for the foam that goes around the plate under the ear pads?
    I also had the Grado SR80 but upgraded to the 225i a few years ago.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • PolkieMan
    No all the foam rotted out years ago, but they still sound very good I think I got them in 1983-86
    skrol wrote: »
    Stan
  • [Deleted User]
    So the burning question for me that I forgot to ask is how this stacks
    up against the other models AFA sound quality for 2 channel?
    Anyone have a shoot out head to head with the different Oppos?
    This against the 83 93 103 in specific.
    tonyb Posts: 33,069
    They are all a step up in sq model to model, especially the SE versions.
