Subwoofer distance
don0
don0 Posts: 78
edited March 2015 in Speakers
My Subwoofer is 12 feet from the main listening seat and Audyssey has it set at 20.5 feet.
My question is which position will most accurately sync with the left and right towers which are 10 feet from main listening seat.?
  • don0
    don0 Posts: 78
    I know that there is someone on here that can answer my question so I am rewording it.
    My Subwoofer is 12 physical feet from the main listening seat but Audyssey has it set at 20.5 feet.
    My question is which position will most accurately blend with the left and right towers which are 10 feet from main listening seat? Do you guys leave it as Audyssey sets it or do you change it in the AVR to the actual physical distance as measured with a tape? Do you experiment with distances in between the two or does your receivers set it correctly all the time?
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    It is setting the longer distance as a method to adjust phase, attempting to smooth out bass response. Setting it to 12ft will increase overall loudness of bass at the cost of quality.
  • Inspector 24
    Inspector 24 Posts: 1,308
    I've experienced this as well, usually with corner loading and longer distance from the MLP.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • mrloren
    mrloren Posts: 2,474
    mine did this as well, it didn't seam to matter but I set it @ 12' to match the speaker that is next to it.
  • don0
    don0 Posts: 78
    edited March 2015
    Thanks for your replies
    I found an old Stereophile test CD that I got years ago. It has base test tones and I played it with the 20.5' setting and the 12' setting.
    There did not seem to be any difference in loudness but I believe that the 20.5' setting sounds best" tighter base" so I left it on the 20.5 setting.
  • ken brydson
    ken brydson Posts: 8,996
    "Bass", just sayin'... pet peeve of mine
