???Taking apart MIT EXp2 speaker cable end???
I have MIT EXp2 speaker cables (got them in the 'wrong ended writing' sale that was posted here a few years back) with both ends terminated with banana plugs from the factory.
I would like to try them on my Klipsch speakers but am unsure and leery that if I take off the ends I don't know what I would be in for!
I really don't want to ruin them but I also can't test them out unless they have bare wire to hook onto the screws at the back of my speakers.
Does anyone know how many strands I am dealing with or if it is a very thick one or two wire make up? I have 5 Mit EXp2 cables and use them for my home theater set up but since I separated and went with a 2 channel only system I would like to try them.
Of course I don't want to bugger them up so not sure what to do to try them out.
Not much info on Mit Cables and older Klipsch speakers, I think spades would work but I dont have any of them either. Maybe be best just to leave them alone and keep the set of 5 for my HT. ah the drama....
Any help is appreciated.
I have some spare ICONN spades...
Thanks Ken B. I am looking into how I can interchange them.
Do the Bananas just screw off or do I have to cut them off. I found this info but it is not clear enough as to how they interchange?
Note: These speaker cables are fitted with MIT's modular "iconn" speaker connector system. This offers a flexible choice of different spade lugs or other connectors. -
They just screw off. I got mine from the same deal you did.
Thanks Ken B. Just found out what you told me! Your faster than Google! Ha Ha!
The iconn system foundation is the Pin Base™, which comes standard on all MIT speaker interfaces. The Pin-Base is threaded to accept iconn spades or bananas, making speaker interfaces work in any system configuration
How much would you want for 4 of them, if you have that many and wanted to sell them? -
Looks like I can get 4 off of Amazon for $29.00 US with free shipping to Canada.
Sounds like a good deal unless someone here has some that they want to sell at a lower cost with free shipping? Not asking for much am I! lol
Thanks. -
PM coming
gfong,
MIT also sells braided wire ICONN ends for use with screw terminals. Look online for the AudioNerd or contact MIT directly.Political Correctness'.........defined
President of Club Polk -
Thanks F1nut will have a look, may work better as the screw terminals on the speakers are small.
Ancient thread, but thought I'd try. Guys, I really need 4 MIT Iconn banana plugs for my exp speaker cables. Found 2 dealers online, selling for $95.00 which I think is a bit steep. Anyone have any extras they're willing to let go of for a more reasonable price? Appreciate it fellas. Trying to rebuild my rig. I have tons of ICs I'm not using now including MIT AVt2, AudioQuest Sidewinder, a pair of Doug's iCs and a few Monster ICs I no longer need. Willing to make a trade if anyone is interested.
TIA,
Mike -
TIA,
Mike
2 things, great to hear from you Mike, hope things are going better. 2nd, reach out to @F1nut . We swapped iconn spades for bananas a few years back and I think he had a stash. -
In use at this time.Political Correctness'.........defined
