???Taking apart MIT EXp2 speaker cable end???
gfong
gfong Posts: 1,079
edited March 2015 in Speakers
I have MIT EXp2 speaker cables (got them in the 'wrong ended writing' sale that was posted here a few years back) with both ends terminated with banana plugs from the factory.
I would like to try them on my Klipsch speakers but am unsure and leery that if I take off the ends I don't know what I would be in for! :) I really don't want to ruin them but I also can't test them out unless they have bare wire to hook onto the screws at the back of my speakers.
Does anyone know how many strands I am dealing with or if it is a very thick one or two wire make up? I have 5 Mit EXp2 cables and use them for my home theater set up but since I separated and went with a 2 channel only system I would like to try them.
Of course I don't want to bugger them up so not sure what to do to try them out.
Not much info on Mit Cables and older Klipsch speakers, I think spades would work but I dont have any of them either. Maybe be best just to leave them alone and keep the set of 5 for my HT. ah the drama.... :)
Any help is appreciated.
  • ken brydson
    ken brydson Posts: 9,077
    I have some spare ICONN spades...
  • gfong
    gfong Posts: 1,079
    edited March 2015
    Thanks Ken B. I am looking into how I can interchange them.
    Do the Bananas just screw off or do I have to cut them off. I found this info but it is not clear enough as to how they interchange?
    Note: These speaker cables are fitted with MIT's modular "iconn" speaker connector system. This offers a flexible choice of different spade lugs or other connectors.
  • ken brydson
    They just screw off. I got mine from the same deal you did.
  • gfong
    gfong Posts: 1,079
    edited March 2015
    Thanks Ken B. Just found out what you told me! Your faster than Google! Ha Ha! :)
    The iconn system foundation is the Pin Base™, which comes standard on all MIT speaker interfaces. The Pin-Base is threaded to accept iconn spades or bananas, making speaker interfaces work in any system configuration
    How much would you want for 4 of them, if you have that many and wanted to sell them?
  • gfong
    gfong Posts: 1,079
    Looks like I can get 4 off of Amazon for $29.00 US with free shipping to Canada.
    Sounds like a good deal unless someone here has some that they want to sell at a lower cost with free shipping? Not asking for much am I! lol :) Thanks.
  • ken brydson
    F1nut Posts: 52,247
    gfong,
    MIT also sells braided wire ICONN ends for use with screw terminals. Look online for the AudioNerd or contact MIT directly.
  • gfong
    gfong Posts: 1,079
    Thanks F1nut will have a look, may work better as the screw terminals on the speakers are small.
  • Keiko
    Keiko Posts: 804
    Ancient thread, but thought I'd try. Guys, I really need 4 MIT Iconn banana plugs for my exp speaker cables. Found 2 dealers online, selling for $95.00 which I think is a bit steep. Anyone have any extras they're willing to let go of for a more reasonable price? Appreciate it fellas. Trying to rebuild my rig. I have tons of ICs I'm not using now including MIT AVt2, AudioQuest Sidewinder, a pair of Doug's iCs and a few Monster ICs I no longer need. Willing to make a trade if anyone is interested.
    TIA,
    Mike
  • ken brydson
    edited July 2
    Keiko wrote: »
    TIA,
    Mike
    2 things, great to hear from you Mike, hope things are going better. 2nd, reach out to @F1nut . We swapped iconn spades for bananas a few years back and I think he had a stash.
    F1nut Posts: 52,247
    In use at this time.
