Fully modded SDA SRS 2.3TL for Sale ---- $1300
Somebody needs to buy these. If I had the $$$, it would already be done! I have tried about a dozen different speakers since I let mine go and NONE have even come close.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Payment plan w pickup at Carverfest perhaps
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I would buy them and have the money. My problem is the distance (probably over 12 hrs one way) and I’d have to measure if they would fit in my vehicle. I’d also need the AI-1 interconnect or dreadnought._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
All obstacles can be overcome. Be sure to measure between the wheel wells or the narrowest part of your vehicle as you'll want to transport them flat on their backs. I fit mine inside a Ford Escape - inches to spare on the sides.
Also, bring padding for between them and on the outsides.
You can do this ! ! !"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
They are well worth the road trip and then some. Perhaps even a night's stay at Casa Sea & Spa Resort... Go for it I say. There will be no disappointments with these.
Sometimes a road trip is the only way. I drove 8 hours each way to get my 1C's from New Jersey, up one day back the next. About a month ago, my wife, son and I made a up and back 22 hour trip to Queens NY to pick up a pair of Carver Amazings.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
Just wondering, have you compared your 2.3s to the SRS 2s?
I've got a buddy hounding me for my 2s and I'm hoping this would be my upgrade avenue, but there's a lot of road between us. Do you have OEM boxes? Are the magnets JB welded?
Thanks!
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
No. I have never heard the SRS 2's. I used loctite power grab on the magnets. Where are you located?Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
PM sentAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I have heard both. Light years apart IMO. These would be a fantastic upgrade!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
The newish Polk site seems to be working "weird"
I was asking if you were open to trades +\- cash . . . .
I have a couple of amps ..... Pass Aleph 30 Class A, Adcom 5503 thrice channel amp and EVS 500M class D monos.....
Oh, an AI-1 1 KVA dreadnaught, too
Just say'nAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Just say'n
I do not need any amps at this point and I have a 1 KVA Dreadnaught from the last group buy. Thanks anyway.
Care to sell the KVA?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Care to sell the KVA?
I am not sure if you are directing that question to me or GlennDog but I still need mine for my SDA 1C system.
Ok.....I have reluctantly put these up on CL.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
The best SDA's come from road trips,,,gives em,,character!
JC approves....he told me so. (F-1 nut) -
And a deeper appreciation for their performancegeorge daniel wrote: »The best SDA's come from road trips,,,gives em,,character!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I would also seek out any "Diners, Drive-in's and Dives" on the way there and back...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Worth the roadtrip for sure.....
If I had the space, these would never see the light of day. Forget the 1.2TL's....these are the sweet spot of the SDA line.
BDT -
^^^YOU^^^
That's driving me crazy. . . . Sea, Did you get my message trhu CL?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Yes. I sent you a PM and responded through CL.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
BDT
^This^
HAAAAAAAAAARRRR
President of Club Polk -
Dang guys, these are rare, especially modded! Can't comment on how they compare to the 1.2TL's as I haven't heard 'em, but my 2.3TL's are stunning. And Sea has done the heavy lifting on the mods - these are plug 'n play.
Let's keep 'em in the Polk family."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Sea...is there any interest in a cash/trade? I have an excellent pair of black studio version SDA-2B.
Conradicles wrote: »Sea...is there any interest in a cash/trade? I have an excellent pair of black studio version SDA-2B.
Thanks for the offer, but I really need to thin the herd a little.
Understood.
BumpMain-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Per the rules, you need 100 posts before buying or selling here.Political Correctness'.........defined
