Swapping Polk Speakers
Current Setup:
-FRONT: RTi12
-SIDES: RT800i
-CENTER: CSi30
-Rear: R20
-Sub#1 PSW303
-Sub#2 PSW110
_Receiver: Onkyo TX-NR929
-Amps: Adcom 5802
Adcom 555
Ok, before we get into debates about amps versus receivers versus speakers timbre matched, I would like to say that I have adjusted and worked at this for a long time. I know that ALL will not agree with amps, speakers, and receiver combos.
What I need is an opinion on replacing my RTi800i's with Bookshelf speakers. I have re-done my Home Theater room, and the Floor standing RT800i's have been very loyal. Unfortunately they don't fit the new set-up. What I need is a Polk Book Shelf speaker that will replace their undying sound quality, without killing the bank.
Opinions & Suggestions with why, are now solicited?!?!?!?!?!?
  • Nightfall
    Nightfall Posts: 10,083
    Budget? Do you already have speaker stands?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • deronb1
    deronb1 Posts: 5,021
    I would 86 the psw110 and spend the money on a better sub
  • ken brydson
    ken brydson Posts: 9,107
    deronb1 wrote: »
    ^^This^^
    F1nut Posts: 52,406
    Are you planning on putting the monitors on a shelf or the like? The reason I ask is because monitors on stands will take up the same real estate as floor standers.
  • dpowell
    dpowell Posts: 3,082
    edited March 2015
    RT55's are probably the closest to the RT800's if you can find a pair used somewhere. F1 is right though you're going to have to put them on something that will eat up the same real estate.
  • WLDock
    WLDock Posts: 3,073
    I second what DSkip says, an RTi set to timbre match the RTi12's seems like a no brainer. What am I missing?
    http://www.ebay.com/itm/Polk-Audio-RTi6-Main-Stereo-Speakers-/131439714524?pt=LH_DefaultDomain_0&hash=item1e9a6ae0dc
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
