Blu Ray Players...Spotify
Are there any Blu Ray players that can stream Spotify? Or am I looking at getting a SONOS and a blu ray player?
Best Answers
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited February 2015 Answer ✓
    Not that I am aware of. However the Amazon fire tv does a fantastic job streaming spotify. It has a free app called spotify connect that allows you to send the spotify stream directly to it while using your smartphone or tablet as the controller. This makes it much easier to navigate the catalog and use all spotify functions such as radio and search easily. I purchased the fire tv primarily for this function. It sounds as good as spotify can at the moment and there is a rumor that spotify will be going lossless in the near future. Oh yeah with the app installed it runs in the background of the fire tv so you never have to turn the tv on to use it. Just click the connect option on the smartphone app and the music starts playing through the fire tv.
    tonyb Posts: 33,072
    You can download Spotify on your computer and stream it to any accepting wi-fi device I would think.
    Roku stick is also a good alternative if that suits you. Is there a reason you want to use a BRP as your streaming device ?
  • jeremymarcinko
    Answer ✓
    Spotify connect capabilities isn't yet available on the pc software. You can connect to and play on the pc from the mobile but not the other way around. You can use third party software such as "stream what you here" (free) to send all of the pc's audio over DLNA, as a work around though. It works very well too.
  • jeremymarcinko
    Answer ✓
    The fire tv (not stick) has an hdmi and optical out that can both be used simultaneously. If that helps. You could run to your dac, assuming it has an optical input and is 48hz compatible ...I think they all are. I only mention this because the fire tv outputs at 48 instead of the typical 44hz.
Answers
  • hochpt21
    hochpt21 Posts: 5,423
    tonyb wrote: »
    The system in my signature is in the living room with the TV and I currently don't have a BR player, but I would like to add one. I would also like the ability to stream Spotify to that system. Thought maybe I could get em both done with the same piece.
  • hochpt21
    Is there a way to utilize that in my system where I want it to run through the dac - integrated - speakers?
  • hochpt21
    Ahh, thank you. I was thinking it was only a stick, but now I see the box.
    tonyb Posts: 33,072
    I think the only BDP's that handle spotify are LG players at the moment.
  • D_M
    D_M Posts: 175
    One of the best all-around media devices ever made, the venerable PS3.
