Armacell Question
machone
Should I remove the old gasket and replace with Armacell or add the Armacell over the old gasket?
If it is recommended to remove the old gasket what is the best way?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Best Answers
The gaskets on the drivers are fine and are not stuck. It's the passive radiator that is the problem. A small portion of it stuck to the baffle, separating its surface and it seems to be really glued to the PR. It may be OK to use as is but I was checking to see what you guys have run into before.
The original gaskets were glued to the basket rim. If they are now unglued they should be reglued or replaced. The PR gasket is the same deal. If it has come loose in one spot, reglue it.
President of Club Polk -
Despite Ray's findings I still maintain there's no point in changing the gaskets unless the originals are damaged. Once a new gasket is completely compressed it will be the same thickness as the original, which is1/64".Political Correctness'.........defined
Answers
The old gasket is preferable if its not torn and in good shape is my understanding. If it is torn, then use Armacell to replace after removing it. It shouldn't need to be removed with anything - it should be loose and not stuck on - at least mine weren't stuck at all on either set of SDA's.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
The gaskets on the drivers are fine and are not stuck. It's the passive radiator that is the problem. A small portion of it stuck to the baffle, separating its surface and it seems to be really glued to the PR. It may be OK to use as is but I was checking to see what you guys have run into before.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Well if it makes you feel better the speakers leak around the dust covers anyway. I guess you could hear a small edge leak with a Stethoscope by gently pushing in on the PR.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
It was my understanding that Armacell is superior to the OEM gasket material and does offer some slight to moderate performance advantages over the stock stuff, or the previously used Mortite. DK did an excellent test of Armacell here.
http://forum.polkaudio.com/discussion/123136/sda-driver-seals-original-foam-vs-mortite-vs-armaflex-foam
Funny that you say they were glued. I had no idea ,I thought they were just laid in place. Mine either lifted then disintegrated or was in shards of dust and pieces so I had to do the Aramflex thing.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
They are glued to the PR and some of it transferred to the speaker baffle. I used Goo Gone to clean it off the baffle. Only the surface of the gasket transferred to the baffle so it may be OK to reuse. If not I will remove it and use Armacell.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
