Armacell Question
Should I remove the old gasket and replace with Armacell or add the Armacell over the old gasket?
If it is recommended to remove the old gasket what is the best way?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Best Answers
    F1nut Posts: 51,936
    Answer ✓
    machone wrote: »
    The gaskets on the drivers are fine and are not stuck. It's the passive radiator that is the problem. A small portion of it stuck to the baffle, separating its surface and it seems to be really glued to the PR. It may be OK to use as is but I was checking to see what you guys have run into before.
    The original gaskets were glued to the basket rim. If they are now unglued they should be reglued or replaced. The PR gasket is the same deal. If it has come loose in one spot, reglue it.
    F1nut Posts: 51,936
    Answer ✓
    Despite Ray's findings I still maintain there's no point in changing the gaskets unless the originals are damaged. Once a new gasket is completely compressed it will be the same thickness as the original, which is1/64".
Answers
  • MrBuhl
    MrBuhl Posts: 2,419
    The old gasket is preferable if its not torn and in good shape is my understanding. If it is torn, then use Armacell to replace after removing it. It shouldn't need to be removed with anything - it should be loose and not stuck on - at least mine weren't stuck at all on either set of SDA's.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • machone
    machone Posts: 1,562
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • PolkieMan
    PolkieMan Posts: 2,446
    edited February 2015
    Well if it makes you feel better the speakers leak around the dust covers anyway. I guess you could hear a small edge leak with a Stethoscope by gently pushing in on the PR.
    nooshinjohn Posts: 25,979
    MrBuhl wrote: »
    It was my understanding that Armacell is superior to the OEM gasket material and does offer some slight to moderate performance advantages over the stock stuff, or the previously used Mortite. DK did an excellent test of Armacell here.
    http://forum.polkaudio.com/discussion/123136/sda-driver-seals-original-foam-vs-mortite-vs-armaflex-foam
  • Funny that you say they were glued. I had no idea ,I thought they were just laid in place. Mine either lifted then disintegrated or was in shards of dust and pieces so I had to do the Aramflex thing.
  • machone
    They are glued to the PR and some of it transferred to the speaker baffle. I used Goo Gone to clean it off the baffle. Only the surface of the gasket transferred to the baffle so it may be OK to reuse. If not I will remove it and use Armacell.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
