Need some help. Tube preamp problem, I think.
ROHfan
ROHfan Posts: 1,014
So I turned on my Mapletree tube pre and let it warm up for a while before listening to some Flim and the BBs. When I stared the CD the left speaker was extremely low and there was no treble. I thought maybe the 198 was fried but when I ran the Oppo through my AVR the sound was fine. I was just listening to the Mapletree last night, no problem. I'm gonna start troubleshooting this afternoon and I was wondering if anyone else has had a similar problem and what was the outcome.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • voltz
    voltz Posts: 5,384
    I had a problem like that with my tube headphone amp, one of the tubes went out and the sound from left channel dropped off completely, change tubes and everything was normal. can you switch tubes to check? as I don't know how you Mapletree is setup.
  • ROHfan
    ROHfan Posts: 1,014
    voltz wrote: »
    I don't have any other tubes but that sounds like a good suggestion. Will let you know if I try that.
  • marvda1
    marvda1 Posts: 4,942
    exchange the position of the two tubes.
    Puritan PSM156
  • ROHfan
    ROHfan Posts: 1,014
    marvda1 wrote: »
    Will try that. If the issue follows the tube=get new tube, correct?
  • marvda1
    correct
    Puritan PSM156
  • polkfarmboy
    polkfarmboy Posts: 5,703
    There is usually visual tell tale signs that tubes are on thier way out. If its obvious then dont swap them round just to experiment as you could fry something. Just for the record this hasnever happened to me.
  • headrott
    headrott Posts: 5,496
    How old is/are the amp and tubes?
  • ROHfan
    ROHfan Posts: 1,014
    headrott wrote: »
    Not sure. I bought it from Face and I'm awaiting his response about the tube type.
    tonyb Posts: 33,069
    Always have extra tubes on hand, anyone with a tubed piece should.
  • ROHfan
    ROHfan Posts: 1,014
    tonyb wrote: »
    Fixed. Just ordered a pair of Russian 6SN7GTs from A-zon.
  • marvda1
    does this one have a switch for using 6sn7 or 12sn7 tubes?
    Puritan PSM156
  • ROHfan
    ROHfan Posts: 1,014
    marvda1 wrote: »
    Yessir.
  • voltz
    voltz Posts: 5,384
    edited February 2015
    I really like the sound of the (Mullard <---oops not mullards) Tung-Sol 6SN7GTB's I got from Tube Depot and use in the Mc100b. and they are about $20 each + $2 for matching.
    Post edited by voltz on
  • marvda1
    voltz wrote: »
    I really like the sound of the Mullard 6SN7GTB's I got from Tube Depot and use in the Mc100b. and they are about $20 each + $2 for matching.
    + how do they compare to the tung sol reissues?
    Puritan PSM156
  • voltz
    voltz Posts: 5,384
    My Bad Marvin...I meant to say Tung-SoL not Mullard....my 12ax7's are Mullards!
  • ROHfan
    ROHfan Posts: 1,014
    As per Lloyd's (from Mapletree) suggestion, I switched position of the two tubes and the problem does not migrate. Still bad left channel. I'm awaiting his response from this news. I guess I'll have to try and rule out the Oppo analog output and the RCA cables as the problem source. Man, I hate pulling the rig away from the wall.
  • voltz
    voltz Posts: 5,384
    dang, was hoping it was something small and easy to fix. hopefully it still is.
  • ROHfan
    ROHfan Posts: 1,014
    voltz wrote: »
    Me, too, but really...is that ever the case? Especially with audio???
  • ROHfan
    ROHfan Posts: 1,014
    Ok, so I'm kind of embarrassed to report that the problem was fixed...by swapping cables.
    I've honestly never heard a cable fail like this before which is why it wasn't my first guess. Previously, my experience with cable failure was either the volume was on or off, or there was a scratchy kind of sound. This was a reduced volume muddiness with no highs. Sounded much worse than it was.
    Thanks go out to all who offered help. Even though this issue probably shouldn't even have reached this forum.
    tonyb Posts: 33,069
    ROHfan wrote: »
    Ok, so I'm kind of embarrassed to report that the problem was fixed...by swapping cables. .
    ....which is why we always suggest to buy well made cables. As an audio rule in troubleshooting, always check the easiest stuff first because more than likely, it is the culprit.
    Don't be embarrassed, know how many times I almost threw a remote out the window only to discover a piece wasn't.....plugged in ?
    heiney9 Posts: 25,430
    I've had cables fail before without any explanation. Also as a general reminder with regards to tube gear. ALWAYS be sure to clean the tube pins! I can't tell you how many noise, level, etc. issue have been completely eliminated by using DeOxit on tube pins.
    If you are using NOS tubes they are 40-60 years old, lots of oxidation present and it doesn't take much to cause all sorts of weird issues
    Glad you got it sorted out.
    tonyb Posts: 33,069
    Nice to see ya posting again pal. You get a new pre and suddenly disappear...lol. Hopefully your done wacking off to it by now and maybe manage a review in comparison to the Dared. Inquiring minds and all that.
    F1nut Posts: 51,723
    tonyb wrote: »
    I worry about you at times.
