winged "c" 6550 replacements
It seems either SED is out of business, or not producing enough tubes.
6550c tubes are a LOT harder to get and $$$.
Any suggestions for modern production tubes?
  • 55LS70
    55LS70 Posts: 184
    I recently replaced my SED 6550's with reissue Tung-Sols. At first I was a little disappointed, but after about 50/60 hours of burning in they are beginning to come around. At this stage I would say the SED's were a little more detailed while the Tung-Sols sound more liquid/smooth. Imagery was better with the SED's but the Tung-Sol's are improving as time goes on. After about the 50 hour mark there was a significant improvement. Honestly I didn't think the Tung-Sols would improve as much as they did while burning in and I also didn't think it would take this long for them to do so. This process seemed much quicker when I was using EL34/KT77 based amps. At this point I still prefer the SED's but if there is any improvement left in the Tung-Sols I would consider them a satisfactory replacement.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • sucks2beme
    sucks2beme Posts: 5,691
    That's what I'd thought about Tung-sol was they were ok (not stellar).
    You can still get some SED's but at a premium.
  • marvda1
    marvda1 Posts: 4,963
    what about the kt88 route? gold lion reissues.
    Puritan PSM156
  • 55LS70
    55LS70 Posts: 184
    marvda1 wrote: »
    Those may be the next quad I purchase. I haven't had my amp very long so thus I've yet to get that far. My Cary is the first 6550 based amp I ever worked with. I've read a few GL KT88 reviews and I must admit I've yet to come across one highly recommending them over the other options. But, as we all probably know, it depends a lot on what components one utilizes.
    sucks2beme wrote: »
    I agree, but if the Tung-Sols I have keep improving, just a little bit, I wouldn't place one above the other. At this time I hoping for a little more clarity. If they don't improve I may try replacing my RCA 5691 (6SL7 variant) drivers with new ones. Those tubes came with the amp when I bought it. The previous owner said they only had four months of use on them and since then I've added another ten months of moderate use. They are heavy duty industrial/military 10,000 hour tubes and they should be okay, but then again who knows. Oh, how I love chasing these demons. Anyway good luck with your amp. I'm sure you'll like whatever tubes you end up with. With all that I said my current amp is still better sounding that the Prima Luna Prologue Four that it replaced. I call that a win situation. Again, good luck.
  • sucks2beme
    ARC doesn't support kt88's and others in place of 6550's.
    They say "may cause issues". Not sure what that means, but
    I'm going to move with caution. Upscale Audio still has them
    at $69 a pop. Not over the top for me, but if you have a
    200 watt piece that would be a wallet biter.
  • sucks2beme
    ok, interesting.
    They seem to have had a change of policy.
    They say the kt88's are a go. Send message to ARC and they
    seem ok with it now. 4 years ago they said NO.
  • thsmith
    thsmith Posts: 6,082
    edited January 2015
    Treasure KT88s are real nice too. I have used TS 6550 originals and the EAT KT88 blow them all away including TS 120s
