Four Outlet Power Strip & Douglas Connection
SCompRacer
A diy shout out for Douglas Connection! He sells completed cables and parts for diy'ers.
http://www.douglasconnection.com/
I built a nicer four outlet box for my two channel system. My two 20 amp outlets are a few feet away from my amp/subs and I don't want to add any wall outlets, so I use a short extension. Before I used a metal four gang box. Visible only when looking behind amp, functional but not pretty.
I got the box on ebay. Doug supplied the cable, Wattgate plugs, Pass & Seymour 8200HI Hospital Grade Duplex Receptacles and Furutech Rhodium IEC. You can go from mild to wild with your budget there. I compared prices and found Doug is among the best deal around for diy parts.
I received no compensation for this message. Just a happy camper.
Now I really like this ^^^^ Nice!
I have speaker cables & Analog cables that Doug has made for me, I have also bought some DIY speaker cables & analog cables from him to make my own that I used on my lesser system, but I use the ones he made on my best system
Doug is the best there is at what he does. I need to give the man a call and just say hi. Been a VERY long time for that.
(I also need about a grand in new cables for my room.)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Looks good, I could sure use something like this to clean things up, cost to buy the parts?Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
~ $222. The box was $81 shipping included from Hong Kong. Good fit and finish, like near 1/4" thick aluminum. It is not a shoddy enclosure. They offer a six outlet box in silver or black too. Hardware to attach outlets included (nuts, washers). I used some adhesive felt pads on the back instead of drilling/tapping and using rubber feet.
IIRC Doug offers Polkies a discount or break with shipping, but I didn't call and ask for it.
http://www.ebay.com/itm/One-US-AC-Power-Supply-Distributor-Aluminum-4-6Outlet-Box-Audio-Grade/231359658136?_trksid=p2045573.c100033.m2042&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20131017132637&meid=823612cd33724532a701962ecf4831ef&pid=100033&rk=1&rkt=2&sd=231359658136Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
