Mediocre Sound Quality of music on LSI series...
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2004
    The easy solution for this test is to burn some MP3's at 320KBPS and then play the CD in a DVD player that supports MP3 formats. Virtually all new DVD players now support MP3 formats. This will remove the unknown hardware issues related to your soundcard.
  • TheReaper
    TheReaper Posts: 636
    edited August 2004
    Originally posted by Sami
    ... there is something wrong in the design of digital audio interfaces ..
    That is the real answer.
    The SPIF/Optical digital audio interface accepted by most receivers, is a realtime stream. The receiver must process and play the audio at the same speed that it recieves the digital stream. Also, because that stream could be the audio for a movie, the stream should be played at almost the same instant as it is received. A good receiver could upsample the stream and re-clock it to match it's DACs to eliminate most jitter. But most receivers don't, because they aren't that sophisticated.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • tjmaxwell
    tjmaxwell Posts: 45
    edited August 2004
    Well, I didn't have time to run through all the tests I said I would, but I can say that listening to a CD in my DVD player was an infinitely better experience than listening through the computer. I didn't have time to try a non-compressed file, perhaps I'll try that later, but it seems that a CD player is indeed the way to go. Thanks to everyone for your advice.
    F1nut Posts: 52,406
    edited August 2004
    Well, now that you're in the market for a CD player may I suggest looking for one that upsamples and even better, one with a tube output stage. Also, go with analog cables vs digital......much better sound that way.
  • malikarshad
    malikarshad Posts: 527
    edited August 2004
    I have a Audigy Platinum card connected to Denon 3803 via digital coax.
    Have you enabled SPDIF pass thru in AudioHQ utility?
    Also in the windows sound settings make your speaker settings to surround sound.
    The computer volume does affect the volume level at your receiver. I always keep my computer volume at max.
    What Software player(winamp, musicmatch, media player) you are using to play your mp3? Some player has EQ enabled that might effect the SQ. I found musicmatch and winamp best on my system.
    Last but not the least have you calibrated the system using SPL meter.
    I hope this helps.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • Sami
    Sami Posts: 4,634
    edited August 2004
    Try a pure wav also, there definately is more difference in sound caused by the compression than jitter. You might find that you cannot hear the difference between the computer and DVD player once you calibrate the sound levels to be equal. Also depending on your DVD player that should be all you need instead of dedicated CD player. Configure the digital output for movies and connect the analog to different input so you can easily configure music differently.
    F1nut Posts: 52,406
    edited August 2004
    All this MP3, wav and using DVD players for CD playback is fine for just hearing music I quess, but if you want to experience the music there is no substitute for a proper 2 channel system, NONE!!!
  • Sami
    Sami Posts: 4,634
    edited August 2004
    Hmmm, do I smell TT's and tube amps in that statement? :)
    F1nut Posts: 52,406
    edited August 2004
    Well, kind of...........no TT, I can't get beyond the snap, crackle and pops. I run a integrated amp with a tubed pre and SS output, the source is a tubed output SACD/upsampling CD player.
  • Sami
    Sami Posts: 4,634
    edited August 2004
    Ah, no TT. No CD player is a substitute for a proper TT. NONE! But your system is fine for just hearing music I quess. :p
  • TroyD
    TroyD Posts: 13,124
    edited August 2004
    Put me squarely in F1's camp. I really want to love vinyl, I really do but it's such a pain and I too can't get past the surface noise.
    BDT
  • tjmaxwell
    tjmaxwell Posts: 45
    edited August 2004
    You guys have gone way over my head now.
    I was actually thinking of upgrading my DVD player to the Denon 3910 when it comes out. It supports all the super audio CD standards I believe (though I'm not sure if it upsamples), and I could utilize the Denon Link on my receiver. Would that be a good solution for movies and music?
  • Sami
    Sami Posts: 4,634
    edited August 2004
    That only means that you haven't put enough money in the TT system. No CD player can come close to a good analog source. A DVD player is much closer to a CD player than a CD is to a TT.
  • Sami
    Sami Posts: 4,634
    edited August 2004
    I am sure it would be. Just configure music and movies separately. You don't want all the bass that movies demand on 2 channel. Also, a good upgrade for your system would be in the subwoofer department.
    F1nut Posts: 52,406
    edited August 2004
    Sami,
    With all due respect, I've yet to hear a TT set up that sounds close to what I run. In fact, it blows away any TT set up I've heard and I've heard some very expensive set ups.
    You're welcome here any time to experience music for the first time. :D
    F1
  • Sami
    Sami Posts: 4,634
    edited August 2004
    LOL. If it is with an inadequate CD player, I don't think so. :p
    Quite honestly I am happy with my LSi7's run with a receiver and source being a DVD player (and sometimes a computer). I can experience music from it and I have heard some of the mega buck systems. I am not saying my system is better, just enough for me to enjoy it.
    The bottom line is not everyone needs a McLaren F1 to enjoy curves on the road.
    F1nut Posts: 52,406
    edited August 2004
    ha....pfffft
    Anyway, as long as you enjoy it, that's all that matters.
  • Sami
    Sami Posts: 4,634
    edited August 2004
    ha....pfffft
    You must have gotten my point. I am sure your system sounds wonderful and I have nothing against CD players. I have nothing against DVD players either, they do a fine job playing CD's. If a CD player is an improvement over DVD player, then TT is a vast improvement. I am just happy with any of them although with TT prepare to spend $$$.
    Absolutely correct. That's all that matters. Mostly it is a matter of being happy with the results AND cost (log10 item:)).
  • dcarlson
    dcarlson Posts: 1,740
    edited August 2004
    F1's system isn't normal. :D
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • sbrst58
    sbrst58 Posts: 13
    edited August 2004
    So TJ, I was looking at a similar system, but using LSI9s for the fronts and a SV sub. How do you like the sound of a music DVD, and CDs? What kind of stuff do you listen to?
    Great forum
  • brettw22
    brettw22 Posts: 7,623
    edited August 2004
    What I've done is when I'm listening to MP3's, I'll boost the bass through my receiver a few notches.
    What I'd suggest is take a track on a cd that you own, download the MP3 version, then compare the two.
    Also, try not using the digital out from your card. Get a cable that plugs into your headphone/speaker output and splits into 2 RCA ends that you can connect to your receiver. That's how I'm connected via my laptop and i haven't ever really had a problem.
    F1, you said something about analog connections being better......but doesn't that pertain to the type of music that he's listening to? Personally, as you know, I'm into the techno/house/trance which a lot of it is electronic. What would be the advantage of taking that digital recording and dumping it down to analog?
    F1nut Posts: 52,406
    edited August 2004
    Brett,
    Are we talking about MP3's played back though a computer or redbook CD's played back on a CDP?
    The main reason I made that comment is that analog cables are just more musical than digital cables, IMHO.
  • brettw22
    edited August 2004
    MP3's played through a computer......I hardly ever buy CD's any more, but the sound isn't THAT much different between an actual CD and an MP3 through the laptop. There are some tracks that sound thinner via laptop, but overall the sound is just fine.
    F1nut Posts: 52,406
    edited August 2004
    If you ever get the chance to hear a CD played back though a upsampling tubed output CDP with good analog cables, I think you'll find a vast difference. :D
  • tjmaxwell
    tjmaxwell Posts: 45
    edited August 2004
    Great forum
    I haven't had the chance to listen to a music DVD yet, but CDs sound great to me just played through my DVD player. I mostly enjoy classical music.
