Mediocre Sound Quality of music on LSI series...
Hi guys,
I finally got my 5.1 surround setup going consisting of a Denon AVR-3805 receiver, an Outlaw 7100 7-channel amplifier, LSi15 fronts, LSiC center, two LSi7 rears, and PSW650 subwoofer. This setup sounds great with movies in Dolby Digital -- lots of powerful sound and clean bass. However, when I listen to music, the bass seemingly all goes away and the sound is just average.
To listen to music, I connect an optical cable from the optical out on the breakout box of my Sound Blaster Audigy2 ZS Platinum Pro sound card to the back of the receiver. The vast majority of my music is in MP3 format encoded with LAME at bit rates around 300-400, so I don't think the problem is related to poor quality MP3s. On the receiver, I set it to "Pure Direct Mode" which the instruction manual indicates is the best for two-channel audio. It sounds decent, but I'm certainly not blown away by it, and the bass is really lacking. I also have to turn up the receiver up above negative numbers to get sufficient volume, even though the volume on my sound card is turned up fairly loud. This volume level would blow me out of the room if I kept it for DVD or TV. Does anyone have any suggestions? Thanks.
I'm not a genius when it comes to bit rates and so forth nor do I know anything about sound cards but I've yet to hear an mp3 that I would bother running through a decent pair of speakers for anything more than ambient noise.
I don't think the problem is your speakers....it's farther up stream.
I figured that probably had something to do with it, but I figured that if the MP3s were encoded at decent bit rates, they'd sound pretty good. I wonder if it would make a difference if I encoded them with no compression.
if you are using an optical output from your sound card why does it matter what your computer volume is set to?
when you are listening to music from the comp. does your subwoofer actually make any sound at all? or is all the bass coming from the front speakers?
how is your sound card configured? for 2 speakers? or a 5.1 setup? if there is a 5.1 configuration i would try that since you are using the optical cable. also, if you want to listen to two-channel, does the break-out box have analog L and R out? if so, try hooking those up and see how it sounds. -
even easier just stick in a cd and listen to it. with bit rates >300kbps I don't think you would hear any difference from a CD but maybe my ears are less sensitive than others. -
The .wav format is at around around 1040kbps I beleive, and MP3s are at most at 360kbp, but expect to see around 128kbps, at most that's three times the bit rate. There should be a huge difference, not only with the lows, but the highs also. The mediocre sound is undoubtedly the bad highs, The highs get compressed and and anything that a tweeter would get is crap. Listen and you will notice, a cymbal shimmering on a MP3 doesn't sound anything remotely like a cymbal. Well what frequencies that are still there, depending on which mode you use, the the highs drop off a little over 11kHz
The LSi series is not meant to be hooked up to the computer. Not trying to offend you, but the computer is a terrible way to hookup, not anything to do with your choice of gear, but with what is involved to make the gear. Any soundcard has a few things to worry about, money, size, and interference. Soundblaster massmarketed the sound cards, sure they put a lot in, but there is a lot they left out. The average Joe may spend 200 for a sound card for a 1337 comp (that's elite
), but not more. Size is the biggest issue, they make it portable, can't be helped, but lets think about it, who can carry their preamp with them everywhere they go, in one hand? Not many. And lastly interferance, the computer does so much, it put all kinds of radiation, which seriously screw around with the sound card, not much else I can say about that. I hope that answers bad sound.
As for thin bass, I really am unsure why.
As for having to crank the receiver, the sound blasters have always been a quiet card, they do not put a very "loud" signal, digital or analog. I hope I answered your question, and here's a good link for more info on your card, maybe it can offer insight, http://www.tomshardware.com/consumer/20031007/audigy-01.html -
Interesting thread.
You have to consider that you are comparing apples to oranges. With the sound tracks for movies being tweaked to give dynamic peaks at certain frequencies and then using MP3's with compression, yep I bet it does sound bad in two channel. Perhaps a real cd player might help. -
Originally posted by F1nut
Interesting thread.
That or a turntable
Mjr, what you're saying is probably true. I believe I read in the manual somewhere that CDs are played at 1200+ kbps or something like that. Though, on my computer, I'm unable to discern a difference between playing a CD and playing a LAME-encoded MP3, but those speakers aren't nearly as good as my Polks.
I'll experiment with a few things when I get home tonight. I'll listen to a CD through my DVD player (currently, my only CD player), then listen to a CD through the computer. I'll also try listening to an uncompressed wav file and compare it to my MP3s. I assume that the difference will be night and day. The strange thing is that much of the LSi demoing was done using one of those MP3 jukeboxes at my local electronics store, and I thought it sounded pretty good. Most of those MP3s were encoded at only 128 as well. Perhaps those have a lot better electronics than a computer sound card though. I just wish now I wouldn't have spent $200 on the sound card. I could've used that money for a 200-disc changer or something.
Anyway, thanks for the help, and I'll report back tomorrow with my findings. -
If he is letting the receiver do the work and only letting the soundcard pass through digital signal, how is it any worse than a standalone CD or DVD player? With analog connection this would be true but with digital it shouldn't make a difference whether he is using a $15 soundcard or $1500 CD player.Originally posted by Mjr7531
The LSi series is not meant to be hooked up to the computer. Not trying to offend you, but the computer is a terrible way to hookup -
Can you tell me what the difference is going to be with digital connection? Am I missing something?Originally posted by Zero
Ditch the Sound Blaster card. If you are serious about your PC sound, which it seems you are.... please visit:
The preamp section of the Denon with the LSi's? He is using Outlaw as the amp.Originally posted by Zero
Next - I dont know how to tell you this, but that Denon and LSi is a horrible match. -
This sounds like it should be true, but alas, it is not, not all CD Readers are created equal. Try this, find a copy of the Telarc 1812 overture, go to the part in the music with cannons and tell me what you hear, with a bad soundcard or portable CD player, you will hear tons upon tons of distortion, on a decent DVD/CD player though, you will hear a glorious cannon blast and then a follow up with either smoke coming out of your speaker or the tinkling of glass from the picture frames that fell off your wall. I may be exagerating, but this is one of the huge adavantages of a more expensive reader, there are so many more though. The biggie is, digital is not perfect, so the more money you put into you digital gear, the better it will sound.
Zero, Thanks for the headsup, I wasn't aware of those cards. I'll have to keep a lookout for those cards, I've been looking to dump my soundblaster for something better for a long time. -
Thanks all for the replies.
I bought the speakers because I ended up getting a really good deal on them, and based on what I've read here, they are excellent speakers. I had originally purchased the Denon to drive them, but found out that the LSi series had 4-ohm impedance. My choices were to change the speakers (which I didn't want to do because of the great price), or get an external amp. The Outlaw came highly recommended, and there was even a post on another forum praising the combination of the Denon 3805 and the Outlaw amp.
I am definitely no audiophile, so I doubt my standards are "too high." This is in fact my first ever foray into home theater and higher-end audio equipment. As stated, I'm very pleased with the sound when watching movies. I thought the ability to hook up the computer to the receiver was simply an "added bonus" since most of my music collection is in MP3 format. I knew there were going to be some limitations in listening to compressed audio compared to standard CDs, but I didn't think the music would be as lifeless as it is. I thought maybe there was something I might've been missing -- a small setting I'm overlooking perhaps. For some reason, the subwoofer seems noticeably absent when I play music, but really booms during movies. Likewise, instrumental music I enjoy just seems to run together.
Like Zero says, maybe it is the sound card. And as much as I'd like to be able to listen to the music collection through the LSi speakers, I'm not sure it's worth shelling out $300-$500 and sacrificing software compatibility just to be able to do this.
Anyway, with some experimentation this evening, I should be able to determine where the weak link is. If CDs sound good, but not uncompressed audio from the computer, I'll know it's the sound card. If CDs and uncompressed audio both sound about the same, the MP3 bit rate is to blame. If CDs sound just as lifeless, then I'll be back tomorrow for more advice.
I think you are still confusing the difference between analog and digital connection. If a computer is not able to handle bits perfectly, it is not worth much as a computer. If it is, then how is there a difference between 01001101 and 01001101?Originally posted by Mjr7531
A $1500 CD player and $15 soundcard should both give the same bit signal to the receiver and thus the exact same sound. Unless someone can prove that the bitstream from a PC and CD player are different, they should sound exactly the same. -
makes sense to me... -
It takes more than bits to make music, even a $1500.00 CD player from one company is going to sound different (better or worse) than a $1500.00 CD player from another company. No two players sound the same, nor do they sound like a $15.00 soundcard.
a CD is recorded as 1's and 0's, right? isn't a CD player that is outputing through the optical cable simply directly feeding those 1's and 0's to the receiver???
if so, then it doesn't matter what CD player you use. if the CD player is working properly, the 1's and 0's will be the same.
if not, then i guess it does matter what CD player you use.
does anyone know for sure if the bitstream on a digital output (optical in this case) is the exact data (1's and 0's) that is recorded on the CD???? -
Nice chart
As long as you are outputting the digital signal and the DAC is located outside of the CD player, I don't see how the CD player should matter at all.
Now if he was using analog outputs, I do agree that the CD player does affect the "sound". But since he is using the digital out from the sound card, the CD player should not matter at all. -
The real problem isn't 1's and 0's, it's jitter.
jitter: A tendency towards lack of synchronization caused by electrical changes. Technically the unexpected (and unwanted) phase shift of digital pulses over a transmission medium. Time skew; a discrepancy between when a digital edge transition is supposed to occur and when it actually does occur - think of it as nervous digital, or maybe a digital analogy to wow and flutter. -
Jitter was the thing I was able to find that would make sense on the sound quality. This could be true if the digital signal isn't timestamped or the DAC can't synchronize it.
interesting. found jitter info here
so i guess shelling out big bucks for a high quality CD player and using its internal DACs versus the receiver is the best way to go? -
In theory, I would agree that 1 and 0's should sound the same but for whatever reason, they don't. In my own rig where I swap out sources and run them through the Denon reciever's digital input, they still sound different.
If you don't think they do, that's cool, but I do think they sound different.
"If we use a VCXO (voltage controlled crystal oscillator) instead of a VCO as a frequency generation device in the PLL circuit, we have a very stable frequency source with low jitter.
The tradeoff is, that it is much more expensive than a VCO and that the frequency control range is very narrow, typically some hundred ppm (parts per million).
That means, that with one VCXO you can receive one sampling frequency. If you design your VCXO based PLL for 44,1kHz, it cannot be used for DAT (48kHz) or DVD (96kHz) applications. This is one of the reasons, why VCXOs are seldom used in DA converters. "
I wonder how much more expensive VCXO is than VCO. This seems like the best way to go about fixing jitter. Too bad I've never seen a receiver/pre give this detailed information about their implementation -
This may be oversimplification, but I'm going to say it anyway: Is your sub turned up enough when listening to music? The LFE track in movies is often recorded LOUD, for more dramatic effect, such that the level of signal that the sub receives in DD is going to be a lot hotter than in "Direct" mode for music playback. I have the Denon 3801, and I find that the sub output level is lower than other receivers I've used.
I agree with those above who mentioned the PC/.mp3 problems, but I still think you should be getting decent sound out of that setup. Makes me think it's a setting or volume issue. Rounding up a CD or DVD player for comparison should shed a little more light.
Jason -
About jitter, it doesn't occur in movies as they should include information about the correct placing of the data. Right? So the jitter problem seems to originate from the Phillips CD format.
where did you see this info about movies? audio on DVD is just a higher bit rate right? -
It is different format. Also they should have it timestamped to know where in the movie to play it. It is up to the DAC how it sounds regardless of the source.Originally posted by PhantomOG
No the transport has alot to do with it as well. If you go into a highend shop and look at the platters on those megabuck cd players you will notice a lot more rigid design. His problem is definitley in using a PC in his sound system. Get a Real CD Player. You shelled out all this money for the rest of the system why skimp here. Sorry to sound so mean but arguing that all 1's and 0's from one product to the next was proven invalid in double blind test in Stereophile Magazine in the mid 1990's. Buy a CD Player.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
On DVD information? That should be all 0's and 1's without any jitter.Originally posted by xsmi
No the transport has alot to do with it as well. -
That all depends on how you play the CD in your computer.Originally posted by xsmi
- If you use the internal connection between your CD drive and sound card, then the CD drive has everything to do with the sound quality.
- If your CD is configured not to use that connector (or it doesn't have one). Then the CD is asynchronously read digitally, bufferred in memory, and sent in blocks to the sound card. Then the sound quality is totally dependant on the sound card's Clock and DAC.
If you have 2 CD/DVD drives in your system, try playing a CD in each. You will normally find that on one drive the light stays on continously (the internal connector is being used), and when the CD is played on the other drive the light flashes (the CD is being digitally read and bufferred).Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
To add to that, if the data is then digitally send to preamp the sound quality should be totally dependant on the DAC on the preamp.Originally posted by TheReaper
If I can send digitally perfect data with my cell phone or between two cheap computer components there is something wrong in the design of digital audio interfaces if I can't do that with a soundcard and a preamp. If the jitter between a soundcard and a preamp really is a problem then I am amazed. Now jitter between the DAC buffer and DAC itself, jitter in the recording, those I could understand.
