Using RTi6 as a Center Speaker
Hi,
So I've been narrowing down my speaker selection and have decided on the RTi8 towers.
I cannot fit the 20" or 24" center channel speakers in my console.
I've been looking at other brands but before I start doing that I thought I'd ask if using the RTi6 as a center (laying flat) would work out.
It is only 14" in height (in this case, wide) so it would fit.
The only other center speaker I can find that will fit is the Paradigm Center 1.
Any advise would be great!
  • jeremymarcinko
    If you don't mind the way it looks, go for it. It will sound just fine.
  • cowboydude99
    Yeah, it's not the ideal way I want to set it up... but until I get a small audio rack, which I can't find anywhere for under $500... I'm stuck with this type of setup.
    Once I can find a rack, I can move the RTi6 to the rears, since they're only sold in pairs.
  • mrloren
    mrloren Posts: 2,488
    yes the RTi6 would work, bummer you can't fit a true center in there
    Family Room:LG QNED80 75", Onkyo RZ50 Emotiva XPA3 GEN3 Oppo BDP-93,Sony UBP-X800BM. Main: Polk LsiM 705 Center: Polk LSiM 704CFront High/Rear High In-Ceiling Polk 80F/X RT Surrounds: Polk S15 Sub: SVS SB-17 ULtra
    Working Warehouse; Denon AVR-3312ci , Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music
  • cowboydude99
    I know... As soon as I find a rack similar to the Sonax CR-2360, I'll get the CSi5... if it is still available.
    I cannot find any enclosed short (around 30") component rack.
