what has better picture
Willow
composite or coax (tv cable) just wondering what might give me a better pic from VCR with the composite or coax cable ??
and why ??
and why ??
Post edited by Willow on
thanks lotsa help !!
composite - because it breaks down the signal to video and audio
thank you that makes sense , right the coax carries both Ill hook it up that way !!
Thanks again -
theoretically the composite will have better picture, but I doubt you'll notice any difference depending on your TV and what you're watching...
Composite is definitely better than coax.
What's a VCR though?
we only use the VCR to tape TV shows when we are not home or watching something else and want to tape at the same time antoher show
This is just an opinion, but when I was at a hotel and had my PS2, I used the cable connection, then later realized the TV had composite. There was a BIG difference IMO. One game I couldn't play because the dark areas (I was in a tunnel) were impossible to decipher anything. With the composite, I noticed there was actually walls and detail to those walls.Brian Knauss
ex-Electrical Engineer for Polk -
I can definitely see that with video game systems becuase you have to go through some kind of RF adapter to get a coax signal...the systems are inherently composite...so yeah I can see going through an extra adapter would make a difference...Originally posted by bknauss
I don't think the difference would be as big with a VCR though...I could be wrong... -
now what if I used somposite from VCR then let the receiver convert to Svideo ???
would this work at all ?? and I guess it would look better ??!! -
depends on the S-Video upconverting capabilities of your receiver...or if it will even pass the composite through the S-Video out...Originally posted by Willow
Definitely worht a try... -
don't know but I have a yammy AV never used the conversion...I should try
Anytime you have a conversion, there's usually going to be a downgrade. I'd just run composite still.
