MBQuart and SVS, same factory?
PolkThug
PolkThug Posts: 7,532
Yep, I'm bored, just stumbled across this and noticed the similarities.
Post edited by PolkThug on
    VR3 Posts: 29,700
    edited August 2004
    simularities?
    They look practically identicle...lol
  • gatemplin
    gatemplin Posts: 1,595
    edited August 2004
    SV subs doesnt make their own drivers. They contract out to TC sounds. So, it is quite possible that TC also makes that MB woofer.
    Edit: actually the only thing that looks similar is the basket, which appears to be a stock unit, Adire Audio also uses it here and I recognize it from the the old Blueprint drivers and a few others as well. It is probably just a coincidence.
    Graham
  • goingganzo
    goingganzo Posts: 2,793
    edited August 2004
    yeah the magnet looks totley different and you dont see the cone or suround. also the specks of the mb i bet has a higher fs and a lower x max
  • PolkThug
    edited August 2004
    The MBQuart has a rubber boot around it.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited August 2004
    The ISD used by SVS is not made by TC Sounds. The dB-12 and the TV-12 are.
    SVS
  • PolkThug
    edited August 2004
    Now, we're getting somewhere. Thanks Doc.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2004
    It could have been made at the same factory, or just have a similar basket.
    I know some Adire prototype drivers that Bassmax was testing had close, if not the same basket also.
    MBQuart is a reputable company in the car audio realm too.
    Cheers,
    Russ
  • Dr. Spec
    edited August 2004
    That is a popular basket design for 12" woofers.
    But the VC, magnet, former, spiders, tinsel leads, cone, and surround are exclusive for the SVS ISD and won't be found in any other driver.
    SVS
  • bknauss
    bknauss Posts: 1,441
    edited August 2004
    The SVS also looks identical to Kove subs (car stuff).
    Brian Knauss
    ex-Electrical Engineer for Polk
