how much dynamat?
dpowell
I want to dynamat the driver baskets in my 2.3TL's and also apply some dynamat to the dreadnaught. Can anyone tell me how many sheets of dynamat I should buy to do these projects?
Start with a starter pack of either 2 or 4 sheets of Dynamat Extreme. 4 should be enough for both.
If you really want to start with 2 sheets, go to ebay to get it. Last I checked a couple of years ago, they do not sell two sheets.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
While you are at it, you should use Black Hole 5 for your 2.3 TLs. I have some available.Statistics show that 98% of us will die at some point in our lifetime.
I buy the 4 sheet door kit, which will be way more than enough. You can use some the rest on things like your Oppo.Political Correctness'.........defined
President of Club Polk -
Let us know your results and comments as this is one thing I have put off as I felt I didn't play them loud enough to notice a difference.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The Black Hole helps at moderate volumes too. Provides increased mid range and bass clarity IME."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Looks like I have some research to do on Black Hole 5. If I'm going to pull the drivers, I'd rather do it just once. Where is the material installed?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
I did not buy a single sliver of the stuff. I found out that the car resto shops use it to deadened trunk and door spaces. I found a place near me and asked if they used the stuff and they said yes and then I asked if they had scraps that they were going to throw out. They said yes go see how much you need and take it. I asked how much and they laughed and said take it and I gave them some coffee money for the day and we were both happy. A somewhat similar story w/BH-5 were I got a nice lead on C/L and bought 1 sheet and again saw pieces laying around and the guy said what you clean up is yours and I cleaned up both figuratively and quite literally. He used a band saw so all the pieces were cut clean and straight. I went old school w/ a phone book and found the audio place near me and the C/L ad also the next town over. Just think out of the box a bit and you can save a bunch of cash.If in Central Jersey IEI Electronics sells small sheets and is very expensive for a 4x sheet.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Good ideas on getting it for free I will check my this small car stereo shop up the streetPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Thought I would update with my results. My wife got me the 4 sheet door kit for Christmas. I have applied dynamat to all of the driver baskets and passive radiators in both 2.3TL speakers. In addition, I have applied dynamat to my dreadnaught and Oppo Blu Ray player. After all of this, I have 1.5 sheets plus a sandwich baggie full of scraps left over for other projects.____________________________________________________________
I honestly just finished the second 2.3TL. I'll have to do some serious listening sessions to know what the results are. What I can tell you is that just doing a finger flick test on the driver baskets before and after was enough to tell me those baskets without dynamat could certainly develop a resonance at higher volumes.____________________________________________________________
