how much dynamat?
I want to dynamat the driver baskets in my 2.3TL's and also apply some dynamat to the dreadnaught. Can anyone tell me how many sheets of dynamat I should buy to do these projects?
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited December 2014
    Start with a starter pack of either 2 or 4 sheets of Dynamat Extreme. 4 should be enough for both.
    If you really want to start with 2 sheets, go to ebay to get it. Last I checked a couple of years ago, they do not sell two sheets.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • While you are at it, you should use Black Hole 5 for your 2.3 TLs. I have some available.
    F1nut Posts: 51,998
    I buy the 4 sheet door kit, which will be way more than enough. You can use some the rest on things like your Oppo.
  • PolkieMan
    PolkieMan Posts: 2,446
    Let us know your results and comments as this is one thing I have put off as I felt I didn't play them loud enough to notice a difference.
  • drumminman
    drumminman Posts: 3,396
    The Black Hole helps at moderate volumes too. Provides increased mid range and bass clarity IME.
  • dpowell
    dpowell Posts: 3,081
    Looks like I have some research to do on Black Hole 5. If I'm going to pull the drivers, I'd rather do it just once. Where is the material installed?
  • I did not buy a single sliver of the stuff. I found out that the car resto shops use it to deadened trunk and door spaces. I found a place near me and asked if they used the stuff and they said yes and then I asked if they had scraps that they were going to throw out. They said yes go see how much you need and take it. I asked how much and they laughed and said take it and I gave them some coffee money for the day and we were both happy. A somewhat similar story w/BH-5 were I got a nice lead on C/L and bought 1 sheet and again saw pieces laying around and the guy said what you clean up is yours and I cleaned up both figuratively and quite literally. He used a band saw so all the pieces were cut clean and straight. I went old school w/ a phone book and found the audio place near me and the C/L ad also the next town over. Just think out of the box a bit and you can save a bunch of cash.If in Central Jersey IEI Electronics sells small sheets and is very expensive for a 4x sheet.
  • PolkieMan
    Good ideas on getting it for free I will check my this small car stereo shop up the street
  • dpowell
    edited January 2015
    Thought I would update with my results. My wife got me the 4 sheet door kit for Christmas. I have applied dynamat to all of the driver baskets and passive radiators in both 2.3TL speakers. In addition, I have applied dynamat to my dreadnaught and Oppo Blu Ray player. After all of this, I have 1.5 sheets plus a sandwich baggie full of scraps left over for other projects.
  • dpowell
    I honestly just finished the second 2.3TL. I'll have to do some serious listening sessions to know what the results are. What I can tell you is that just doing a finger flick test on the driver baskets before and after was enough to tell me those baskets without dynamat could certainly develop a resonance at higher volumes.
