how much dynamat?
dpowell
I want to dynamat the driver baskets in my 2.3TL's and also apply some dynamat to the dreadnaught. Can anyone tell me how many sheets of dynamat I should buy to do these projects?
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
Start with a starter pack of either 2 or 4 sheets of Dynamat Extreme. 4 should be enough for both.
If you really want to start with 2 sheets, go to ebay to get it. Last I checked a couple of years ago, they do not sell two sheets.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
While you are at it, you should use Black Hole 5 for your 2.3 TLs. I have some available.Statistics show that 98% of us will die at some point in our lifetime.
I buy the 4 sheet door kit, which will be way more than enough. You can use some the rest on things like your Oppo.Political Correctness'.........defined
President of Club Polk -
Let us know your results and comments as this is one thing I have put off as I felt I didn't play them loud enough to notice a difference.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The Black Hole helps at moderate volumes too. Provides increased mid range and bass clarity IME."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Looks like I have some research to do on Black Hole 5. If I'm going to pull the drivers, I'd rather do it just once. Where is the material installed?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
I did not buy a single sliver of the stuff. I found out that the car resto shops use it to deadened trunk and door spaces. I found a place near me and asked if they used the stuff and they said yes and then I asked if they had scraps that they were going to throw out. They said yes go see how much you need and take it. I asked how much and they laughed and said take it and I gave them some coffee money for the day and we were both happy. A somewhat similar story w/BH-5 were I got a nice lead on C/L and bought 1 sheet and again saw pieces laying around and the guy said what you clean up is yours and I cleaned up both figuratively and quite literally. He used a band saw so all the pieces were cut clean and straight. I went old school w/ a phone book and found the audio place near me and the C/L ad also the next town over. Just think out of the box a bit and you can save a bunch of cash.If in Central Jersey IEI Electronics sells small sheets and is very expensive for a 4x sheet.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Good ideas on getting it for free I will check my this small car stereo shop up the streetPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Thought I would update with my results. My wife got me the 4 sheet door kit for Christmas. I have applied dynamat to all of the driver baskets and passive radiators in both 2.3TL speakers. In addition, I have applied dynamat to my dreadnaught and Oppo Blu Ray player. After all of this, I have 1.5 sheets plus a sandwich baggie full of scraps left over for other projects.____________________________________________________________
I honestly just finished the second 2.3TL. I'll have to do some serious listening sessions to know what the results are. What I can tell you is that just doing a finger flick test on the driver baskets before and after was enough to tell me those baskets without dynamat could certainly develop a resonance at higher volumes.____________________________________________________________
