Possible centers for RTi A5
French_guy
French_guy Posts: 338
edited December 2014 in Speakers
Hello
What are all the possible center channels that will match with the Polk RTi A5?
If I order the RTiA5, I should also enjoy the 50% off for the proper center....
I think there is in the "A" serie the RTi A4 and also the RTi A6
But there is also the older serie, which is the CSi3 and CSi5
CSi3 is at $105 on Polk Ebay, while the CSi A4 will be ~$125
CSi A6 seems better, but much bigger as well......Is the sound difference really worth twice the price?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
    gudnoyez Posts: 8,183
    Get the CSIA6 I had the CSIA4 at first then I kept reading on centers go big or go home it literally bugged me wanting to hear the difference so I bought the A6 sold the A4 a few days later. It is a beast so make sure you got room for it, better make up your mind 1 day left.
  • So what about the difference: is it worth the price and size?
    Will it be ok with rtia5?
    No surround...yet
  • Arghhh......They are out of stock for the CSi A6 cherry. So now my option is to get the CSi A4 (50% off) or the CSi5 from Polk Ebay for $215....
    Not sure what is best.....!!!!
    No surround...yet
  • Get the csia4 then, it will match your mains aesthetically and will sound just fine. The a6 or csi5 will sound better but considering the availability of the a6 and the different looks of the 5, I wouldn't hesitate to get the 4 at that price.
    EndersShadow Posts: 17,741
    Dont buy a center and wait for a CSi A6 to popup on Polks ebay site. You will get a refurb (that should look like new) w a 1 year warranty, free shipping and its discounted.
    The center is the MOST important channel and I'd go big or go home.
  • I agree the csi6 will be better, but a new a4 for only $125 is a great deal. If he decides to get an a6 at some point he won't have any trouble getting his money back out of the 4. The 4 is a good center that will certainly be better than no center and besides it's going to look great with the new mains.
  • Yeah, i pulled the trigger and ordered the Csia4
    I may get later a csi5 or csi a6 from Polk ebay with their "hassle freel" return policy to make some tests
    if much better, i should be able to sell the csi a4 without loosing money
    No surround...yet
  • Hey man if you do find a csi a6 at a good price later, jump on it. I played with both the a4 and a6 and i went for the a6 with my rti a9's. Have to get the best center that you can afford that matches the fronts and you will always have a good sound stage to build from.
  • will do......waiting to receive my new speakers, and later on will try to find a good deal on a CSi A6
    But isn't it too big for the A5?
    No surround...yet
    No
    The CSIA6 And the RTIA5s both have 6 1/2 inch drivers the CSIA4 has 5 1/4 inch drivers so the A6 matches the A5s perfectly having owned both the A4 is not a bad center to go with your A5s congratulations by the way, but the A6 is a better match and makes the perfect front soundstage.
  • I keep reading the CSiA6 is FAR better than the CSiA4....
    I hope i haven't done a mistake ordering the smallest one... But it was a good price though
    I have to rearrange my curent TV bench anyway, using some Ikea Besta cabinets, and i will have to make sure i have room for the CSiA6....and keep an eye on some great discount or used!!!!
    No surround...yet
  • Dude the a4's will do you fine, the a6 is better but the a4 at that price was a steal. Have a play with it and if you are happy with the sound than theres not need for an upgrade but if you are left wondering than by all means go after the a6.
  • yep, that's the plan.......will have to find a place to get the CSiA6 for test !
    No surround...yet
    The A4 is a fine center give it time to break in you will be happy with it save your money for that AVR you want the reason I sold my A4 was because I sold it to a buddy along with one of my AVRs. I got the A6 because I was ready to upgrade my AVR to one with preouts and 3 channel amp.
    In other words the A4 will be fine until you are ready to upgrade the rest a little at a time, one thing I can tell you I have spent a lot of money since joining this forum easy goes it don't go for it all at once think of the WAF B)
  • What is good in this hobby is to have somehow a "long term plan": if money was not an issue and you could get whatever you want and whenever you want it, it would be less fun. My next expense will be to build my TV bench from some IKEA Besta cabinets
    And also make some comparative tests (in stereo) between my current TSi300, my new RTi A5, and some old Jamo Alto Signature (bookshelf) from 2 different AVRs: my Pioneer VSX920 and and old JVC RX888.....
    No surround...yet
