Monitor 7B driver polarity?
wingzam
Hey,I am putting together a pair of 7B's but am confused as to how to wire the woofer/driver.There is a red dot next to one post but want to confirm which wire goes here,the white or the black?
Thanks!
Thanks!
On vintage Polks, Black is Hot/+, White is Ground/-.
The red dot indicates Hot/+Home Theater/2 Channel:
dhsspeakerservice.com/ -
Red is the new black
After done, you can check polarity with a battery.
Alright you guys,Thanks!
OK Mystery ya got me - how do I check the polarity with a battery? -
Once you are done plugging everything, use a 1.5v or 9v battery and connect battery +ve to speaker +ve and battery -ve to speaker -ve terminals.
If the woofer moves out, they are correctly wired.
If the woofer moves in, the polarity is reversed.
Check both speakers to confirm they move out.
Here is a video for individual driver.
https://www.youtube.com/watch?v=xIMHGkxw72o
Ha,that is the coolest thing I've seen all week!
I would recommend a 1.5 volt, and only touch the battery terminal momentarily, enough to see the cone move. You don't want 9 volts dc hitting the tweeter coilHome Theater/2 Channel:
westmassguy wrote: »I would recommend a 1.5 volt, and only touch the battery terminal momentarily, enough to see the cone move. You don't want 9 volts dc hitting the tweeter coil
So,can I do this with an assembled speaker by connecting the 1.5V batt. to the external binding posts? -
YesPolitical Correctness'.........defined
President of Club Polk -
I personally would not do it on a vintage Polk. If you wired the tweeter and woofer correctly, and the binding post's colored caps are correct (red left, black right), you should be fineHome Theater/2 Channel:
Yes,No..OK,I think I'll not test them this way.If I've learned anything in all these years it's to say No to temptation!
Got the 7's back together and they sound good.
I think I'll rebuild the crossovers sometime soon and see what that does for them.
