is my midrange blown?
I have a pair of RTI 10 speakers. the midrange driver on one speaker has started to make a noise similar to a kazoo ( musical instrument that vibrates a paper membrane when blowing through it) at a certain frequency. I swapped midrange drivers between speakers to make sure problem is with driver. What could the problem be, and is it repairable? if not repairable, what is a replacement going to cost me. Am in New Zealand.
  • BlueFox
    BlueFox Posts: 15,250
    Sounds like a bad midrange. In the past, I had a woofer with the same issue. Check with Polk customer service for the cost plus shipping.
  • drumminman
    drumminman Posts: 3,396
    Let Polk CS know you're a forum member and you get a discount on the replacement driver.
  • ok thanks guys, Polk dealer priced it at $60 plus frieght for a replacement, not very expensive, so am happy
