is my midrange blown?
plumberdan
I have a pair of RTI 10 speakers. the midrange driver on one speaker has started to make a noise similar to a kazoo ( musical instrument that vibrates a paper membrane when blowing through it) at a certain frequency. I swapped midrange drivers between speakers to make sure problem is with driver. What could the problem be, and is it repairable? if not repairable, what is a replacement going to cost me. Am in New Zealand.
Sounds like a bad midrange. In the past, I had a woofer with the same issue. Check with Polk customer service for the cost plus shipping.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Let Polk CS know you're a forum member and you get a discount on the replacement driver."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
ok thanks guys, Polk dealer priced it at $60 plus frieght for a replacement, not very expensive, so am happy
