Monitor Series or RTi?
Mjr7531
Mjr7531 Posts: 856
edited August 2004 in Speakers
I have a CSi5 Center and I love it, I was wondering, should I switch to the monitor series?
I have two options, buy the RTi6 and eventually get the RTi12s (It's my dream to get them, don't bother to defer that)
Or to trade in My CSi5 for a CS2 and get the Monitor 40 and eventually fill out my system with the Monitor 70s?
It's either CSi5, RTi12, and RTi6, *or* Monitor 40, Monitor 70 and CS2, What would be better off? (Disregarding money)
  • tecmo04
    tecmo04 Posts: 421
    edited August 2004
    i have the csi5 and monitor 70. i enjoy the combo a great deal. ive never heard the csi5 with the rti series but there probably isnt that much of a difference. but i personaly wouldnt waste my money on bookshelf speakers when you know your going to upgrade later. wait it out a little and buy what u like and what sounds good to you. the main thing in my mind to remeber is that both speakers will sound great especialy with the csi5. thats my 2cents
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2004
    Switching the Csi5 for a Cs2 would be a downgrade. The Csi5 has a better freq response and higher watt handling, and the Csi5 weighs 8lbs more! :)
    Regards,
    PolkThug
  • stereo55
    stereo55 Posts: 418
    edited August 2004
    IMO , definitly go with the CSi5 and the RTi line . As PolkThug pointed out , the Monitor series is a down grade from the RTi line . I would keep to your original thought of the RTi12's and 6's , or a close combo of that (RTi10's , etc ) .
    Check your local CircuitCity's for "close-out" prices on the RTi line and/or demo's ; since CC is no longer going to carry this line . Believe me , you can grab a great deal if you hurry and do some CC searching , as the close-out has being going on for some time now .
    *NOTE*
    (do a search here at the forums under "CircuitCity" , and you'll see some of the great deals that have been had during this close-out)
    Good luck .... ;)
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • Toxis
    Toxis Posts: 5,116
    edited August 2004
    Monitor = Entry Level Polk
    RTi = Mid Line
    LSi = Creme de la creme.
