Let's design "The" SDA Center Channel Speaker
Conradicles
There was some talk of this a while back but it seems this project never developed.
With the Minds we have here on the forum, why don't we do this?
I was thinking of a TL model and a standard model with the two most common tweeters. Maybe two different sizes (one huge and one big)!
Ideas?
Ideas?
Post edited by Conradicles on
Could a CRS+ be repurposed as a center? In my imagination the dimensional MW would become a regular driver and the IC jack would be plugged. I have no idea what to do with the crossover.
I also did some drawings of a center using the gubbins of a Monitor 10 with a box reshaped similar to the CS 1000, keeping the internal volume the same. The PR would be placed on top. The box ended up 36"W x 17.89"D x 7.25"H. Would the Monitor 10 crossover work in the same volume but a much flatter shape?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Jim
That's my thought as well, a single CRS + would probably make an ideal center channel to match with other SDAs used as front mains. -
The vintage section of this very site calls the CRS+ a "Center Channel":
"SDA CRS+ Classic Polk Center Channel Speaker"
http://www.polkaudio.com/products/sdacrs
and
"The only center channel speaker worthy of SDA"
These statements confuse me since I thought the CRS was originally not a center channel but a Compact SDA.Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
I do love my center, and so does everyone who's heard it. I plan on raising the tweeter at some point. It will require modifying the plastic bezel, filling and re-veneering however. If I'd allowed more room for the tweeter, I could have mounted it higher, and horizontally.Maybe some real inspiration in the following thread ?
http://www.polkaudio.com/forums/showthread.php?150760-My-Center-Channel-ProjectHome Theater/2 Channel:
dhsspeakerservice.com/ -
If you used an 86' CRS+, you could drop in a Monitor 10 crossover. The Later model CRS+ would require replacing the 6511 driver with another 6503. Problem is, where to find a single CRS+, unless two go in on the purchase.Could a CRS+ be repurposed as a center? In my imagination the dimensional MW would become a regular driver and the IC jack would be plugged. I have no idea what to do with the crossover.
JimHome Theater/2 Channel:
Thanks. I love it, and my surrounds are all timbre matched as well.I bet it sounds good, a lot of thought and time went into it. I just had to link to the project cause well, it's cool and outside the box.Home Theater/2 Channel:
westmassguy wrote: »If you used an 86' CRS+, you could drop in a Monitor 10 crossover. The Later model CRS+ would require replacing the 6511 driver with another 6503. Problem is, where to find a single CRS+, unless two go in on the purchase.
This could work for me as I have a 1988 pair of Monitor 10s whose boxes are in poor condition. Would moving the crossover to a smaller box, but same drivers be OK or is redesigning the crossover necessary?
I could use the CRS+ center with my SDA-1bs, although in my set up I like the CRS+ pair better. I have been on the lookout for another set of the baby SDAs.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
The 10s should be 6503s I believe. Transplant the drivers, crossover and tweeter from the 10 to the CRS+.Home Theater/2 Channel:
I'm thinking an RTA 15TL would make an awesome center. It is already MTM. lay it on it's side and now you've got a serious center channel speaker. Would just need to remove the tweeter deflectors.If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
westmassguy wrote: »The 10s should be 6503s I believe. Transplant the drivers, crossover and tweeter from the 10 to the CRS+.
But does the smaller box of the CRS+ have no effect on the design requirements of the crossover?
Also, why would I need to transplant the tweeters? They both had the SL-2000 until I put the RDO-194s in the CRS+. Also, if I find another pair of CRS+, is there any reason not to do the TL upgrade on all three?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
And you would also have lobing by placing it on it's side.Mr. Bubbles wrote: »I'm thinking an RTA 15TL would make an awesome center. It is already MTM. lay it on it's side and now you've got a serious center channel speaker. Would just need to remove the tweeter deflectors.
I had something in the works a while back, I'll revisit it this week."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I didn't know what tweeters you had. The 86' CRS+ used two 6510s, which are close enough to the 6503s. The only thing you may have to do, is pad down the tweeter with a .75 ohm resistor instead of the .5 ohm used to replace the Polyswitch.But does the smaller box of the CRS+ have no effect on the design requirements of the crossover?
Jim
"TL"ing all three would be very good, that's what I have.Home Theater/2 Channel:
I think an 8T would be more manageable. It's ported, so no PRs. Plenty of room on the baffle to raise the tweeter upMr. Bubbles wrote: »I'm thinking an RTA 15TL would make an awesome center. It is already MTM. lay it on it's side and now you've got a serious center channel speaker. Would just need to remove the tweeter deflectors.Home Theater/2 Channel:
I absolutely agree. But hey it has lobeing now, just in the vertical plane and as all centers with multiple driver, it would also have lobeing in the horizontal plane. That is just the nature of any multi driver speaker unless it's a point source unit. A design like the Vandy VCC-5 would be awesome but there is no vintage Polk full range or point source driver to work with. On the 15 the drivers are already mounted in very close proximity to each other to reduce the effects of lobeing issues as much as would be present in another good ready made center like most other Polk centers. In fact the driver proximity would be much better than most Polk centers produced in the past creating less lobing than those models.If con is the opposite of pro, is Congress the opposite of Progress?!
That is what I have always thought. The 8T and the 8TL may be the perfect choice with a slight redesign of the cabinet style keeping the internal volume the same.
Conradicles wrote: »That is what I have always thought. The 8T and the 8TL may be the perfect choice with a slight redesign of the cabinet style keeping the internal volume the same.
In all matterof correctness, accuracy, and SQ i would agree with this. The reason i mentioned the 15 is just because it would be bad ****. kind of like the SRS and 1.2TL's. To me the most basic of the SDA's "sounds" the best. (maybe not in every single aspect but over all) This is primamrily due to the minimal lobing, fewer source points of radiation, etc. Much of it associated with the basic design and fewer components. However I wouldn't give up either my SRS or 1.2TL's for another set of SDA 2's. Another reason is that my HT is totaly seperate gear from my 2ch rigs. Rarely is HT the cleanest, most detailed sounds we will hear like in our 2ch listening. Again i just mentioned it because it would be bad **** for HT! My choice again would be a point source design or a full range design like the Vany VCC-5. This would give true center focus with no lobing at all other than the radiation pattern of the single driver.
Another thought would be to design a sort of progressive point source like the SRS tweets and bring the focus back to the center somewhat like a focused array.If con is the opposite of pro, is Congress the opposite of Progress?!
Or maybe a dedicated midrange above/below a RDO and flanked by a pair of MW woofers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Bump to see if anybody wants to get this project finished. We need specs/dimensions of the ultimate SDA center speaker.
and
That's what I've read on the vintage sight, I guess I have 4 SDA center channels then. We're you spose to use per say 2bs as fronts and 1 CRS+ as a center with out the SDA cable, all I would need is a 5 channel amp And I could have a all SDA surround rig the rears would be without the SDA cable connected Correct?
If I were using a CRS+ as a center, I'd swap out the crossover with a Monitor 10 crossover, and change the MW6511 to the 6503 or 6510, to match the stereo woofer.Home Theater/2 Channel:
An alternate for using the CRS+, would be to keep the existing crossover. Disconnect and safe-off the dimensional woofers wiring. Install two MW6511 woofers, and wire them in Series off the stereo woofer's harness.
You would probable have to play with the value of the Resistor that replaces the Polyswitch. The Tweeter's output may have to be increased.Home Theater/2 Channel:
here is a link to a 1 speaker CRS being sold on ebay but it is not a CRS+
http://www.ebay.com/itm/Vintage-Polk-Audio-SDA-CRS-Compact-Reference-System-Right-Speaker-Only-Black-/231403168334?pt=Vintage_Electronics_R2&hash=item35e0b4224e
It is a CRS+, note the pin/blade interconnect sockethere is a link to a 1 speaker CRS being sold on ebay but it is not a CRS+
Ah cool! I remember seeing this for awhile now and was thinking it may never sell by itself but now maybe it will.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Reviving this thread;
Definitely ant to make a Home Theater package pull of SDAs. To this day (though I', only 30) the SDAs are the best bang-for-the-buck sound of anything I've heard. I currently have a pair of Polk SDA 2B's and a pair of Polk CRS's and am dying to get some Polk SDA SRS 2.3's ;-)
Most of the links above are broken, what do you all think is the best setup for a 5.1 system using Polk SDA 2's or 1's as the front L/R stage?
Thanks in advance! -
I've seen a set of CRS used above and below the screen as a center before. Otherwise the CS400i is I believe the center of choice...Post edited by EndersShadow on"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Is the CS400i TimbreMatched to Polk SDA's? It looks quite different (not to mention ugly IMHO ;-) )
Yes it can be used on SDA's. I used one with my 2b's & they are wonderfulRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
That is absolutely awesome!boston1450 wrote: »Yes it can be used on SDA's. I used one with my 2b's & they are wonderful
Thanks so much.
Bump for folks who want the best SDA Center ever made.
