Let's design "The" SDA Center Channel Speaker
Conradicles
Conradicles Posts: 6,400
edited April 2014 in Vintage Speakers
There was some talk of this a while back but it seems this project never developed.
With the Minds we have here on the forum, why don't we do this?
I was thinking of a TL model and a standard model with the two most common tweeters. Maybe two different sizes (one huge and one big)!
Ideas?
Post edited by Conradicles on
  • jimbo1421
    jimbo1421 Posts: 772
    edited April 2014
    Could a CRS+ be repurposed as a center? In my imagination the dimensional MW would become a regular driver and the IC jack would be plugged. I have no idea what to do with the crossover.
    I also did some drawings of a center using the gubbins of a Monitor 10 with a box reshaped similar to the CS 1000, keeping the internal volume the same. The PR would be placed on top. The box ended up 36"W x 17.89"D x 7.25"H. Would the Monitor 10 crossover work in the same volume but a much flatter shape?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2014
    jimbo1421 wrote: »
    Jim
    That's my thought as well, a single CRS + would probably make an ideal center channel to match with other SDAs used as front mains.
  • Zentish
    Zentish Posts: 127
    edited April 2014
    The vintage section of this very site calls the CRS+ a "Center Channel":
    "SDA CRS+ Classic Polk Center Channel Speaker"
    http://www.polkaudio.com/products/sdacrs
    and
    "The only center channel speaker worthy of SDA"
    These statements confuse me since I thought the CRS was originally not a center channel but a Compact SDA.
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2014
    nbrowser wrote: »
    Maybe some real inspiration in the following thread ?
    http://www.polkaudio.com/forums/showthread.php?150760-My-Center-Channel-Project
    I do love my center, and so does everyone who's heard it. I plan on raising the tweeter at some point. It will require modifying the plastic bezel, filling and re-veneering however. If I'd allowed more room for the tweeter, I could have mounted it higher, and horizontally.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    edited April 2014
    jimbo1421 wrote: »
    Jim
    If you used an 86' CRS+, you could drop in a Monitor 10 crossover. The Later model CRS+ would require replacing the 6511 driver with another 6503. Problem is, where to find a single CRS+, unless two go in on the purchase.
  • westmassguy
    edited April 2014
    nbrowser wrote: »
    I bet it sounds good, a lot of thought and time went into it. I just had to link to the project cause well, it's cool and outside the box.
    Thanks. I love it, and my surrounds are all timbre matched as well.
  • jimbo1421
    edited April 2014
    This could work for me as I have a 1988 pair of Monitor 10s whose boxes are in poor condition. Would moving the crossover to a smaller box, but same drivers be OK or is redesigning the crossover necessary?
    I could use the CRS+ center with my SDA-1bs, although in my set up I like the CRS+ pair better. I have been on the lookout for another set of the baby SDAs.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • westmassguy
    edited April 2014
    The 10s should be 6503s I believe. Transplant the drivers, crossover and tweeter from the 10 to the CRS+.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited April 2014
    I'm thinking an RTA 15TL would make an awesome center. It is already MTM. lay it on it's side and now you've got a serious center channel speaker. Would just need to remove the tweeter deflectors.
  • jimbo1421
    edited April 2014
    But does the smaller box of the CRS+ have no effect on the design requirements of the crossover?
    Also, why would I need to transplant the tweeters? They both had the SL-2000 until I put the RDO-194s in the CRS+. Also, if I find another pair of CRS+, is there any reason not to do the TL upgrade on all three?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • Face
    Face Posts: 14,340
    edited April 2014
    And you would also have lobing by placing it on it's side.
    I had something in the works a while back, I'll revisit it this week.
  • westmassguy
    edited April 2014
    jimbo1421 wrote: »
    Jim
    I didn't know what tweeters you had. The 86' CRS+ used two 6510s, which are close enough to the 6503s. The only thing you may have to do, is pad down the tweeter with a .75 ohm resistor instead of the .5 ohm used to replace the Polyswitch.
    "TL"ing all three would be very good, that's what I have.
  • westmassguy
    edited April 2014
    I think an 8T would be more manageable. It's ported, so no PRs. Plenty of room on the baffle to raise the tweeter up
  • Mr. Bubbles
    edited April 2014
    Face wrote: »
    I absolutely agree. But hey it has lobeing now, just in the vertical plane and as all centers with multiple driver, it would also have lobeing in the horizontal plane. That is just the nature of any multi driver speaker unless it's a point source unit. A design like the Vandy VCC-5 would be awesome but there is no vintage Polk full range or point source driver to work with. On the 15 the drivers are already mounted in very close proximity to each other to reduce the effects of lobeing issues as much as would be present in another good ready made center like most other Polk centers. In fact the driver proximity would be much better than most Polk centers produced in the past creating less lobing than those models.
  • Conradicles
    edited April 2014
    That is what I have always thought. The 8T and the 8TL may be the perfect choice with a slight redesign of the cabinet style keeping the internal volume the same.
  • Mr. Bubbles
    edited April 2014
    In all matterof correctness, accuracy, and SQ i would agree with this. The reason i mentioned the 15 is just because it would be bad ****. kind of like the SRS and 1.2TL's. To me the most basic of the SDA's "sounds" the best. (maybe not in every single aspect but over all) This is primamrily due to the minimal lobing, fewer source points of radiation, etc. Much of it associated with the basic design and fewer components. However I wouldn't give up either my SRS or 1.2TL's for another set of SDA 2's. Another reason is that my HT is totaly seperate gear from my 2ch rigs. Rarely is HT the cleanest, most detailed sounds we will hear like in our 2ch listening. Again i just mentioned it because it would be bad **** for HT! My choice again would be a point source design or a full range design like the Vany VCC-5. This would give true center focus with no lobing at all other than the radiation pattern of the single driver.
    Another thought would be to design a sort of progressive point source like the SRS tweets and bring the focus back to the center somewhat like a focused array.
  • Face
    Face Posts: 14,340
    edited April 2014
    Or maybe a dedicated midrange above/below a RDO and flanked by a pair of MW woofers.
  • Conradicles
    Bump to see if anybody wants to get this project finished. We need specs/dimensions of the ultimate SDA center speaker.
    gudnoyez Posts: 8,185
    Zentish wrote: »
    and
    That's what I've read on the vintage sight, I guess I have 4 SDA center channels then. We're you spose to use per say 2bs as fronts and 1 CRS+ as a center with out the SDA cable, all I would need is a 5 channel amp And I could have a all SDA surround rig the rears would be without the SDA cable connected Correct?
  • westmassguy
    If I were using a CRS+ as a center, I'd swap out the crossover with a Monitor 10 crossover, and change the MW6511 to the 6503 or 6510, to match the stereo woofer.
  • westmassguy
    edited November 2014
    An alternate for using the CRS+, would be to keep the existing crossover. Disconnect and safe-off the dimensional woofers wiring. Install two MW6511 woofers, and wire them in Series off the stereo woofer's harness.
    You would probable have to play with the value of the Resistor that replaces the Polyswitch. The Tweeter's output may have to be increased.
  • voltz
    voltz Posts: 5,384
  • westmassguy
    voltz wrote: »
    It is a CRS+, note the pin/blade interconnect socket
  • voltz
    voltz Posts: 5,384
    Ah cool! I remember seeing this for awhile now and was thinking it may never sell by itself but now maybe it will.
  • bingmobo
    Reviving this thread;
    Definitely ant to make a Home Theater package pull of SDAs. To this day (though I', only 30) the SDAs are the best bang-for-the-buck sound of anything I've heard. I currently have a pair of Polk SDA 2B's and a pair of Polk CRS's and am dying to get some Polk SDA SRS 2.3's ;-)
    Most of the links above are broken, what do you all think is the best setup for a 5.1 system using Polk SDA 2's or 1's as the front L/R stage?
    Thanks in advance!
    EndersShadow Posts: 17,742
    edited August 2015
    I've seen a set of CRS used above and below the screen as a center before. Otherwise the CS400i is I believe the center of choice...
    Post edited by EndersShadow on
  • bingmobo
    Is the CS400i TimbreMatched to Polk SDA's? It looks quite different (not to mention ugly IMHO ;-) )
  • boston1450
    boston1450 Posts: 7,758
    Yes it can be used on SDA's. I used one with my 2b's & they are wonderful
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • bingmobo
    boston1450 wrote: »
    That is absolutely awesome!
    Thanks so much.
  • Conradicles
    Bump for folks who want the best SDA Center ever made.
