LSim703
Lowell_M
Lowell_M Posts: 1,660
edited November 2014 in Speakers
Due to the configuration of my new living room, I'm looking to replace my trusty LSi15's. The new two channel system won't be ideal, but I'd like some input regarding what to expect and/or recommendations...
I have built-in cabinet on each side of a fireplace. Current plan is to put LSi703's on top of the cabinet... so about 7' up :( and I have an SVS SB13Ultra that will go in one of the base cabinets behind some acoustic mesh. Am I going to be happy with this setup? Will imaging suck? Do I need to "aim" the LSim703's so that they point down toward the listening area?
supporting gear... ADCOM GFA555, Outlaw 975 preamp, ALAC files on computer.
Oh... looks like I haven't updated my signature in a really really long time, so don't pay much attention to it...
Thanks, Aaron
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
    F1nut Posts: 52,000
    Any speaker that high up isn't going to give you the best sound even if they are angled down.
  • Lowell_M
    So, this seems like a ridiculous question because I'm no sure how you would quantify it but...how bad will it be? A waste of an LSim or just not as good as it could be??
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • hochpt21
    hochpt21 Posts: 5,423
    I could be wrong, but my thought would be that if that is the ONLY place you could put a speaker....you would want the best speaker possible there.
    Of course, it wouldn't be ideal, but again, if that is the ONLY place your situation would allow, I don't think it would be a waste of any speaker.
    And the LSiM's are VERY nice speakers.
  • Lowell_M
    I'm used to a pretty nice sounding, pure, 2-channel system which is what makes this decision suck. Sad to give up the Lsi15's but nut sure I have a great alternative.
    Oh...love the SVS SB13 Ultra though. Already integrated that with the LSi's in another room for now.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • hochpt21
    Do you have any space in your new setup for a properly placed speaker?
    Also, that is a hell of a sub, but not sure how it will sound in a cabinet.
  • Lowell_M
    No space for a proper setup I did check with Svs regarding the sub in the cabinet and as long as it is as close to the front of the cabinet as possible, all should be fine. The sub is a beast but the room is 40' long and 19' wide.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • hochpt21
    If that's what you have to work with...don't worry about going with the 703's. They will make you happy and it will not be a waste.
    F1nut Posts: 52,000
    Lowell_M wrote: »
    Kind of like being an ant on the ground in front of a stage.
  • Lowell_M
    I'll get squished by the mosh pit?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • fyrn
    fyrn Posts: 146
    Have you consider lsi7's. You could hang those pretty much anywhere
  • Lowell_M
    Yea. I did consider Lsi7's, but the volume of the room these are going into is huge and I thought the LSim703's would do a better job filling the room with sound. Since I'm happy with my LSi15's, I could probably try the 7's and see if I'm happy with them.... but the situation is also an opportunity for me to step up the new LSim's as well. That is, of course, unless my less than ideal placement will negate the benefits of the Lsim703's over the Lsi7.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
