Unable to open any pictures
drumminman
Anyone else having this issue? Specifically, clicking on the links to photos in various threads all cause a "Not Found" window to open.
Hello,
Can you give a specific example?
Thanks, Ken -
The img tagged jpg pics here:
http://forum.polkaudio.com/discussion/134278/nspindels-sda-crs-upgrade-thread
and other pics here:
http://forum.polkaudio.com/discussion/163238/crs-in-the-house#latest
I'm think the 2nd post (mine) was made after the transition to the new forum, so that's probably not it. I also remember clicking on the links in the first post and being able to see the pics after the transition.
Thanks for your help Ken."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
No problem, I'll check with Vanilla.
Any word on the pics issue?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Well, there could be a small number of attachments that were part of the old forum that were not successfully imported into the new forum. This fact wasn't caught in time to be corrected during the transitional approval period. I'm sorry for that.
However there are no known problems with recent attachments, correct?
Ken -
The 2nd post was made on August 6 - wasn't that after the transition?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I'll check to see when it happened.
According to the information I've received from Vanilla, the transition happened on August 20th which would be after the problem you experienced.
Ahhh, that explains it. Thanks for checking Ken. At least I know it's not an issue with the forum."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
