Unable to open any pictures
Anyone else having this issue? Specifically, clicking on the links to photos in various threads all cause a "Not Found" window to open.
  • [Deleted User]
    Hello,
    Can you give a specific example?
    Thanks, Ken
  • drumminman
    drumminman Posts: 3,395
    The img tagged jpg pics here:
    http://forum.polkaudio.com/discussion/134278/nspindels-sda-crs-upgrade-thread
    and other pics here:
    http://forum.polkaudio.com/discussion/163238/crs-in-the-house#latest
    I'm think the 2nd post (mine) was made after the transition to the new forum, so that's probably not it. I also remember clicking on the links in the first post and being able to see the pics after the transition.
    Thanks for your help Ken.
  • [Deleted User]
    No problem, I'll check with Vanilla.
  • drumminman
    Any word on the pics issue?
  • [Deleted User]
    Well, there could be a small number of attachments that were part of the old forum that were not successfully imported into the new forum. This fact wasn't caught in time to be corrected during the transitional approval period. I'm sorry for that.
    However there are no known problems with recent attachments, correct?
    Ken
  • drumminman
    edited November 2014
    The 2nd post was made on August 6 - wasn't that after the transition?
  • [Deleted User]
    I'll check to see when it happened.
  • [Deleted User]
    According to the information I've received from Vanilla, the transition happened on August 20th which would be after the problem you experienced.
  • drumminman
    Ahhh, that explains it. Thanks for checking Ken. At least I know it's not an issue with the forum.
