800VA Dreadnaught
westmassguy
This new project is very similar to my last, but with a few twists. I started with the same prefinished, cast aluminum case, The entire exterior was covered in blue painters tape to guard against overspray, and nicks or chips in the paint. The mounting holes for the Toroid, SpeakONs, and Rubber Feet were drilled and dressed. Three Coats of Aluminum Primer, and Two Tops coats were applied. The Copper foils is a PITA to install, but worth the effort. Dynamat Extreme was then applied to all surfaces. The Toroid was mounted on a 6" diameter piece of 1/2" MDF. The MDF was prepped for installation of Nylon wire ties. The foam cushion supplied with the Toroid was used with the MDF. I installed Dynamat on top of the Toroid before securing the wire ties. This will help mitigate any resonances, and provide a pliable barrier between the wire ties and the windings. The assembly was bolted to the case with #1/4-20 Stainless Flat Head Cap Screw, Stainless Lock Nut, and Stainless Fender Washer. The Black Chrome SpeakON Sockets were also installed with Stainless Machine Screws, Washers and Nuts. No Magnetic/Ferrous Metal is contained in the project.
Brass Spade/Quick Connects were installed, and final connections made. Through-Hole Rubber Feet were put in place. As a last step, Rigid Foam was installed to protect and secure the Toroid During shipping.
Home Theater/2 Channel:
dhsspeakerservice.com/
Beautifully done!
Great project.
Thank you sharing it.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Looks very nice! Now you just need a 1000VA Dreadnought.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Moose68Bash wrote: »Beautifully done!
Great project.
ThanksHome Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks, but I can't use either with my 2AsHome Theater/2 Channel:
Looks like a labor intensive project, nice work Dave!
Nice work Dave! I used the same wire tie/platform method to attach the Solen 10 AWG SDA inductor to the floor of my 2.3TL's several years ago. Wanted to keep the center of gravity low.
"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Thanks drummin, that's why I use the 1/2" MDF. On a vertical orientation, it moves the Toroid to the center of gravity in the enclosure. Otherwise, it's unstable.drumminman wrote: »Nice work Dave! I used the same wire tie/platform method to attach the Solen 10 AWG SDA inductor to the floor of my 2.3TL's several years ago. Wanted to keep the center of gravity low.
Built my first Dreadnought and the new one without the copper foil. Wonder if I should go back and put it in? Or do the new one and compare (after burn in)."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
The Aluminum is great for RF Shielding, Copper is better for EMI. The combination, plus additional Aluminum from the Dynamat, gives you a broad spectrum of shielding.
I'd rather have both even if EMI Shielding isn't always necessary.Home Theater/2 Channel:
Excellent work there Brother!!
