Help with HT Setup
I'm new to audio setup and been thinking about getting a 7.2 surround sound setup.
I'm set on getting the Onkyo TX-NR626 as my amp.
My living room does not have a left wall since it opens to the nook which opens to kitchen. So I can't mount speakers at ear level but I can either get OWM3 using mounts and point them down at the listening area, or get RC80i and point the tweeters down.
I like the RC80i because they will be in the ceiling and I won't have anything hanging down.
I'm thinking about getting the Polk OWM3 as my rear. I don't mind them since they will be mounted in the corner of ceiling to back wall.
Center channel will be the Polk CS10. I plan to get two Polk Subwoofers, probably the PWS10.
I will also invest in some floorstanding speakers.
I'm more concern should I use the RC80i or the OWM3 as my side speakers? Should I go OWM3 all the way around or even RC80i all the way around?
  • Dennis Gardner
    If you don't have the speakers yet, I would match speakers if possible. The in ceiling models do seem like they would work better with no speakers being shown. The RC 80is have a ball and socket tweeter mount that lets you swivel the tweeter toward your seating for better directional control of the signal.
    Just my opinion, I'm sure others will chime in.....
  • specd_out
    specd_out Posts: 504
    Dont get the psw10. Combine the money you would spend and buy one better sub. There are a lot of good subs that will be in the $300-$400 range.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
