Looking for a small/mini subwoofer
F1nut
F1nut Posts: 51,789
edited October 2014 in Speakers
I've done a little looking, but thought I'd ask for suggestions/comments. I need a small/mini subwoofer for my shop. It will sit on a large shelf along with a TV, AVR, 2 small satellites and a small center. The shelf is rock solid, so no concern there. That said, I'd like to keep the sub at or under an 11" cube. It needs to be front firing, have an LFE connection and be powered with auto on/off. It also needs to be a sealed design, ported just will not work as it will be more or less in a corner.
These are 2 I've looked at so far, http://www.nhthifi.com/Subwoofer-home-theater-Super-8?sc=12&category=3779#image-4
http://www.psbspeakers.com/products/subwoofers/SubSeries-100-Subwoofer#heading-downloads
Talk to me.
«13
    EndersShadow Posts: 17,705
    Jesse.... What about an older Sunfire true sun junior......
  • Mikey081057
    Mikey081057 Posts: 7,127
    This little guy looks intriguing but it has dual drivers...
    http://www.sunfire.com/atmosXT.asp
    Garage | Polk Monitor 5B's
    gudnoyez Posts: 8,165
    http://www.svsound.com/subwoofers/sealed-box/sb-1000
    To bad you did not have an extra 2 inches to spare. I would love this one or the 2000 myself some day!
    F1nut Posts: 51,789
    Dan, it rolls off quick at 60Hz.
    Mikey, intriguing indeed, but yeah the dual woofers won't work.
    Steve, wish I had the room for that one.
    F1nut Posts: 51,789
  • Mikey081057
    Bottoms at 28 and fits the size req's
    Looks like a winner...can you get a demo?
  • drumminman
    drumminman Posts: 3,396
    edited October 2014
    I have an older model Velodyne I bought new around 2000. Still works the same as the day I bought it. Much older technology (class AB amp), but very good quality, very good sound. I wouldn't hesitate to buy another.
    That one looks like it fits your requirements.
  • westmassguy
    westmassguy Posts: 6,850
    Only thing I'd be concerned with on the Velodyne, is Customer Service, Support, after warranty parts etc.
    I have not heard good things about them.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mikey081057
    edited October 2014
  • voltz
    voltz Posts: 5,384
    I like the PSB :) but that is just because I like PSB speakers!
  • ken brydson
    ken brydson Posts: 9,005
    I'd buy the SVS and see if you can make it fit. 45 day return policy and free shipping both ways. Nothing to lose....
    F1nut Posts: 51,789
    I'm leaning toward the Velodyne, it's a bit deeper than I'd like, but the width and height are perfect, goes low too. I looked around for service problems, but didn't see a whole lot of issues. One guy was bitching about no parts for his 20 year old sub.....cry me a river.
    I like the NHT for size and all, but it seems it should go lower. That new Sunfire still rolls off too low. The SVS I know will not fit, I always measure twice, cut once. I like the looks of the PSB, but man, it's smaller than the satellites....just ain't right, ya know....LOL
  • WLDock
    WLDock Posts: 3,073
    edited October 2014
    Wow, $900 budget for and 8"? You are serious! Looks like a beast of an 8".
    I was looking for a small sealed myself to mate up with my KEF sats to go in my bedroom but the KEF Kube-1 is more than I want to pay. I was thinking of making one maybe using the Dayton RS driver or JBl GTO804 as I have very limited space next to the dresser. Only a small cube or tall narrow ported will fit. However, I came across the Pinnacle SUBcompact8 that I am considering...it does have a crossover bypass switch for LFE HT use also.
    Webpage: http://www.pinnaclespeakers.com/subcompact8.html
    ebay ~$185 shipped
    http://www.ebay.com/itm/Pinnacle-Speakers-300-Watt-SubCompact-8-Powered-Subwoofer-NIB-/251677331366?pt=Speakers_Subwoofers&hash=item3a99234fa6
    http://www.ebay.com/itm/PINNACLE-SUBCOMPACT-8-SUBWOOFER-NICE-/231332844185?pt=Speakers_Subwoofers&hash=item35dc831299
    About the only feedback I can find is below. The first guy thought only the Velo Minivee sounds better overall from the few compact subs he has heard...but thought the Pinnacle was pretty good.
    http://www.audioreview.com/cat/speakers/subwoofers/pinnacle/speakers-subcompact-8-subwoofer/prd_438783_2741crx.aspx
    http://www.audiokarma.org/forums/showpost.php?p=1663301&postcount=7
    http://www.amazon.com/review/R1F3N44GOFLQOG/ref=cm_cr_rdp_perm
    http://www.amazon.com/review/R2C063H7PO39YF/ref=cm_cr_rdp_perm
    http://newyork.craigslist.org/fct/ele/4709223423.html
    http://www.head-fi.org/t/518279/need-a-good-2-1-system-cant-figure-out-which-ones-i-really-want/15
  • deronb1
    deronb1 Posts: 5,021
    I love my little 8" velos. Front slot ported. Very musical.
    F1nut Posts: 51,789
    Yeah I know, a $900 sub for a shop rig is just a bit crazy considering that it is more money than the brand new TV and AVR put together. Thanks for the lead on the Pinnacle, it looks very promising. I've heard of the company, but have never heard any of their products. That may change very soon.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Lot's of good leads here......aren't you a woodworker with mad skills in the electronic field?? Why not build one to your exact specs and call it a wrap?? I'm thinking it would be one bad **** unit and something to be real proud of, plus who knows..the makings of a new "low end authority" ?? That's the kind of faith I have in you bro!
  • WLDock
    WLDock Posts: 3,073
    edited October 2014
    DIY can be a great thing sometimes. I was really into building 8's for light SQ bass back in my car audio days. I love showing this pic of my old eD e8A I built. I loved this mini cube...I even used it upfront on the center hump in an old beater I had.
    There are other cool drivers (like the JBL GTO804 in my first post) around that will make for a nice small sealed system for home use. The RE Audio REXv2-8 is another. Great specs, great price! 24.5Hz Fs, 13mm XMAX
    http://reaudio.com/products/woofers_rex.php
    http://www.sonicelectronix.com/item_77320_RE-Audio-REXv2-8.html?utm_source=google&utm_medium=cpc&utm_campaign=PLA&scid=scplp7130944&gclid=CNS_mNrAucECFQtgMgodEkgAPw
    However, by the time you buy the driver, cheap $100, 200W amp, materials, etc you are at the cost of something like the Pinnacle sub above....not sure of how much of a performance difference there is?
    As far as besting the Velodyne MiniVee with a DIY sealed 11" cube? Don't think there are any drivers that will do that? Even the JL Audio W7 needs a larger enclosure to work. The MiniVee cost $900 for good reason. It uses a pretty beefy driver engineered for small sealed that has a composite resin/Kevlar cone, oversized aluminum frame, oversized spider, oversized rubber surround, oversized voice coil, and 12.7 lbs magnet! Mated with a super efficient 1000 watt amp, DAMN!
    image_mini
    I...seriously doubt there is anything else this size that can top this sub.
    http://www.audioholics.com/subwoofer-reviews/velodyne-minivee
    ...but I could not spend $900 for a sealed 8" sub.... unless I really needed it to do a lot of work and had no others options that would fit...and I had that type of cash laying around. Still, I'm sure the modest priced yet over achieving Pinnacle sub is all many would need for a small system....and the price is about the most I would spend for such a limited situation.
    Now in terms of DIY 18" subs for HT....there is a cost to performance and DIY pride that makes sense. Given some of the good and affordable drivers available as well as affordable high power class D and pro audio amps available today. Hard to beat a pair of Stereo Integrity HT18's for $300, A 2000 watt Peavey IPR2 2000 for $360, and build/buy a couple of MartyCube enclosures/flatpacks for $200-$400. DIY and used is the only way to get that much bass for under$1K. New would be at least twice as much.
    A system like this would literally shake the small 1400 sq ft rental home I currently live in, to pieces. Just the RT3000p subs alone get things rattling pretty good. When I buy again hopefully I will have more space and a dedicated music and/or theater room. I then plan to build my 2 ch speakers, another sub, and who knows what else.
    Post edited by WLDock on
  • erniejade
    erniejade Posts: 6,321
    I am a fan of the smaller velodyne sealed box subs. Musical, fast and deep. I have a bigger spl1200 and I did have a power supply issue a few years ago but, a local shop fixed it for like 100 or 120$.
    I have heard a few NHT products. It's one of thoes company's people forget about how musical their speakers and subs sound.
    It would be a hard call for me between the NHT and the Velo.
  • voltz
    voltz Posts: 5,384
    How about a REL Acoustics T5 * its a 8 inch 150watts
    http://www.audioadvisor.com/prodinfo.asp?number=RLT5
    F1nut Posts: 51,789
    Thanks everyone for your thoughts and suggestions. I bought the Pinnacle Subcompact 8 as it fit my needs the best.
  • PSOVLSK
    PSOVLSK Posts: 5,383
    Under budget!!!
    Please send Will a sixer of Miller Lite to replace the empty in his picture. :D
    @ZLTFUL‌ .. I give you twenty dollars....
  • erniejade
    Let us know what you think of it please.
    F1nut Posts: 51,789
    I use NHT monitors in my office. I'd say they were ok stock, but after crossover mods they are a far better speaker and yes, very musical. What's amazing is they hit 38Hz using a 6.5" driver in a small cabinet.
    Yeah, I owe him.
    Beautiful subs and I looked at them but they fire down and I need a front firing.
    Was going to offer up my DSW Micropro 2000 as an option
    Thanks, but too big (I think) and the PR fires down.
  • WLDock
    WLDock Posts: 3,073
    PSOVLSK wrote: »
    Under budget!!!Please send Will a sixer of Miller Lite to replace the empty in his picture. :D
    Yeah, I owe him.
    The name is Walt (Walter). and I'm actually more of a wine and hard cider drinker...and lightweight at best.LOL!
    I hope the sub works out. I can use one of them myself...but tall and narrow is what I really need. Like this one:
  • PSOVLSK
    Walt...I knew that. My apologies.
    Great find on the sub.
    F1nut Posts: 51,789
    So, I bought the new Pinnacle SubCompact 8 from the eBay seller last Tuesday. Says it would be here on Friday the 24th, says item location Bethpage, NY. Nope to both. Shipped from Gardena. CA and didn't get here until today, but that's not the worst of it. The outer box says SubCompact 8, but the sub inside is the PS Sub 8-300. I'm not happy!
  • erniejade
    Ouch!
    F1nut Posts: 51,789
    edited October 2014
    Need to make one correction, I bought it on Monday, 10/20/14, not Tuesday, 10/21/14. Makes it even worse.....getting madder by the minute.
  • Mikey081057
    Ebay makes it pretty easy to return ... that aside I'd be madder than a wet hen too... hate it when them ebayers try to get one over... did he use the "maybe we can settle this by you offering me something for something you don't want" routine? First thing I do with those guys is file a claim/complaint so they know you ain't in no mood to eff around.
