New Binding Posts | AI-1 Dreadnaught
audiocr381ve
audiocr381ve Posts: 2,588
edited October 2014 in Vintage Speakers
Glenndog sent me a beautiful AI-1 Dreadnaught and I can't use it until I update the SDA connection on my CRS+'s.
I'm having trouble understanding how to make the connection. Because there are two binding posts for each channel on the AI-1, does this mean I'll need to install two posts for the SDA connection on each of my speakers?
I'm a little confused because I've seen people install a single post for the SDA connection, like this:
Would an ideal route be to install single posts on each speaker and have custom speaker cables made by Doug that go from two conductors on one end (the AI-1 end) to combined conductors (at the speaker end)?
Hope this all makes sense and thanks in advanced!
    F1nut Posts: 51,898
    You need two separate connections on the speakers as well as the case. What some have done is use one new binding post for the positive and connect the negative from the case to the existing negative binding post. A better idea is to use a single SpeakOn connector on the speaker, which has separate +/- connections.
  • Do as Jesse says Shane. The speakon is the best way to do this.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • audiocr381ve
    I figured I was a little late on doing it this way since the AI-1 came with binding posts (and nice ones at that!). I'm not sure I have the tools to modify the case further. Is there a post I can find to help me visualize what it would take to go SpeakOn?
  • westmassguy
    westmassguy Posts: 6,850
    Put a SpeakON Socket in place of the Pin/Blade Socket on each Binding Post Cup. Make two cables, each terminated with a SpeakON Plug on one end, and Two Banana Plugs or Fork/Spades on the other. You don't have to modify the case.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • audiocr381ve
    Gotha, where should I purchase the SpeakOn connectors from?
    F1nut Posts: 51,898
    Parts Express sells them, but there's plenty of other places.
    F1nut Posts: 51,898
  • audiocr381ve
    Thanks for the help Jesse. So I found a page full of em' and I'm not sure which ones to grab.
    https://www.parts-express.com/cat/speakon-hpc-speaker-connectors/1510
    I see 2 pole, 4 pole, and 8 pole.
  • TNTsTunes
    TNTsTunes Posts: 751
    Get the 4 pole ones, but only use 2 poles. I was told the 4 pole ones are built better.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    F1nut Posts: 51,898
    As the man said, get the 4 pole version.
    I used the NLT4FX-BAG male connector and the NLT4MP-BAG female chassis socket.
  • email coming to ya....
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • stogie
    stogie Posts: 230
    Doug sells the speakons also.
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
    EndersShadow Posts: 17,715
    @helipilotdoug‌
    Doug is one of the forums best kept secrets, and I hope it gets out there more.
    Snag some parts from him, or even have him make the cables for ya...
    SCompRacer Posts: 9,121
    edited October 2014
    Just a suggestion if you use the four terminal SpeakOn. I attached the pin wire to -2 terminal and blade to -1 terminal. On the 2.3 xover I did, in the schematic 2 is indicated as the pin terminal, 1 the blade. Both are negative polarity so it makes sense to use -2 and -1. I haven't checked but presume the CRS+ would follow the same numbering for pin/blade since other SDA schematics do. Wire your choice of interconnect cable the same way. Kind of flows with continuity if you know what I mean.
    For a cleaner look I prefer the flange mounted 'inny' method, but this depends on thickness of plate. With this VR3 plate, there is just enough room to attach the connector without binding or the release hitting the Allen head fasteners I used.
  • dpowell
    dpowell Posts: 3,081
    I ordered a set of plates from VR3 with the binding posts, speakon connector for the SDA IC and wiring harness ready to plug and play for my 2.3TL's. He does quality work. I'm quite happy with them.
