SDA-1C Refurbish Plan
If you need any pointers give me a hollarHome Theater/2 Channel:
dhsspeakerservice.com/ -
Ok. Done and reinstalled. I took my time and it took about 4 hours including installing neutrick connectors in the back plates in place of the pin/blade connector. I went with Dayton 1% in the low pass, ClarityCaps in the high pass and Mills resisters. They sound good now but I am told that as they break in the sound may get worse and then better. Thank you to all of you that did this before and posted. I learned a lot. My soldering would not win any appearance awards but I think the solder joints are sound.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
