Do Rotel amps generally share a common ground, RA870BX.
hifi junky
I'm wanting to use my connection cable between my SDA 2b's , my current power amp is a Sansui B2102 which is not common ground. I'm considering purchasing a Rotel RA870 BX. Although it doesn't have as high of an output as the Sansui, I'm hoping it would allow me to use the connecting cable .
Any advice is appreciated.
Best Answer
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Answers
I guess I could use a multi tester to check continuity across the left and right speaker ground posts.
The Rotel does share a common ground according to the multi tester. So I am good to go if I choose to use the interconnecting cable for the SDA's.
I'm currently using the Rotel amplifier as a pre amp for my non common ground Sansui power amplifier.
My new question is as follows , continue to use a 200 watt per channel high power and or use the Rotels common ground internal amp at 80 watts per channel allowing the use of the SDA's interconnecting cable.
I know it's a personal taste, but again advise would be appreciated.
