Record Cleaning Machines - DIY or Purchase - Who uses one?
The VPI, Nitty Gritty and Spin Clean will all clean your records. Some involve more hand work and time. The machine is just part of the process. Chemicals, rinse, cleaning brush, anti static sleeve, drying cloths, micro fibre brushes, etc. are all part of the system. Vinyl is a real pain LOL! But, I'm hooked!
Ultrasonic cleaning is coming in a big way. DIY and consumer ready units are going become more affordable. The market is ripe and ultrasound is a step up in cleaning quality.Carl -
I did buy a VPI 16.5 used many years ago. I go a little over board and use the Audio Intelligence three step (enzyme, cleaner, pure water) with three different brushes and three different wands. This is only when I first acquire the albums. Afterward a swipe with the anti static brush is all they need. The enzyme step, once I started using it, made the most difference with background noise and pops. Many albums I had previously cleaned were redone with enzyme and greatly improved. The torque of the RCM vs a converted TT is really the only benefit comparing the two. I agree with schwarcw that ultrasonic is going to be the direction of the future.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
...so in the mean time I recommend going digital and sell your LPs to a fellow Polk member.
rednedtugent wrote: »...so in the mean time I recommend going digital and sell your LPs to a fellow Polk member.
Ha!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Get a KAB EV-1 and a $30 shop vac from sears and you will be good to go:
https://www.kabusa.com/ev1.htm
Total package cost $200 and it is as effective as any vac cleaning machine on the market.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
The VPI 16.5 rocks.Vinyl, the final frontier...
Obsession18 wrote: »Get a KAB EV-1 and a $30 shop vac from sears and you will be good to go:
So with this combo you scrub on the top? and then turn it over to vacuum it?
with the VPI 16.5 you scrub and vacuum from the same side and it turns the record for you with enough power to deep scrub as you hand controls the brush pressure since its in your hand. easy as pie. piece of cake
You may want to look at this thread....
http://forum.polkaudio.com/discussion/163898/i-stopped-in-at-transparent-music-today#latestPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Yes, scrub on top, flip to vac. One of the things that sold me on this unit was the external vac, if you have a failure - $30 for another small shop vac and your back in business. Also, not as loud with the vac on the floor, I checked out a VPI 16.5 and man is that thing LOUD.2-Channel System
That is amazing. No way I could afford one of those new ultrasonic cleaners - but honestly, with that heated tank from Amazon, the machine is pretty simple with a low speed rotary after that. Very tempting indeed. I may have to give that a shot.
Can always make a DIY vacuum machine for drying purposes as a final step as well.
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I picked up one of the 60kHz Ultrasonics, USA-made, for less than $400.For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
doctorcilantro wrote: »I picked up one of the 60kHz Ultrasonics, USA-made, for less than $400.
WHere?
WHere?
Probably this one 6 Quart 60kHz VIBRATO Ultrasonic Cleaner. 375 + shipping....
https://www.tindie.com/products/VibratoLLC/6-quart-60khz-vibrato-ultrasonic-cleaner/
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
anyone have any thoughts about the whole 60hz vs 40hz bubble size and cleaning in the groves debate? Opinions on if it's really a sizable difference (quality of clean-wise)?VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Check this out.
http://www.zenith-ultrasonics.com/ultrasonic_frequency_selection.htmPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Did you build one of those cool rotisserie motor cleaners?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
[/quote]
Check this out.
http://www.zenith-ultrasonics.com/ultrasonic_frequency_selection.htm[/quote]
Hmm - interesting. Why to I feel like that budget line I'm not going to cross is starting to move again. Seems like you could make a case for 40 or 60 - maybe 60 is the sweet spot but both seem effective in the DIY I have seen.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Good reading in the morning here folks......anyone own the Oki Noki....I found a discounted demo version and it looks like replacement parts are easy to find. Honestly I am between this and the manual spin clean because I am so cheap.....so sway me either way!!
I use a kit I bought (out of canada, nick) 3dcanfab.com. fantastic deal about 115.00. Plus I built the plenty and it does a great job. Make my own cleaning solution (25% 99.999 isopropyl, 75% RODI water and a drop of triton x14 wetting agent).Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The pictures I've seen of the Okki noki looks like it works just like my VIP 16.5. and that would make it a good record cleaner in my books!
you just tighten down the record and add fluid and brush it as it spins then vacuum it off rinse & vac again! makes cleaning with these machine A Simple choir.
and you don't need a lot of fluid to clean , just a little bit of cleaner then distilled water to rinse is all that is needed.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I use a VPI 16.5 also. It has worked great for me. Just follow the instructions given by Voltz in the post above.
I ended up with a Nitty Gritty MiniPro1, cleans, vacuums and scrubs both sides at the same time for a quicker turnaround. It's a good unit, and Nitty Gritty still does a great factory service for pretty reasonable pricing - I got it used off the 'bay and shipped it to NG to have it gone through, good as new now!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
My NG MiniPro2 is a time saver - as mentioned by MrBuhl it cleans both sides at once. I typically hand scrub first using MoFi brush and Deep Cleaner, put LP on NG and vacuum, then add one-step cleaner from reservoir on NG (NG Pure solution), vacuum, sleeve the clean LP, sleeve the jacket. Avg. about 2 mins/LP[
