I stopped in at Transparent Music today
I went to demo the Rogue Atlas Magnum power amp. The setup consisted of a Well Tempered turntable with a Dynavector 20XH cartridge, Sonus Faber 2 ways book shelve speakers and a Cronus Magnum integrated amp. This has the same power amp section as the Atlas. I really enjoyed the demo but the thing that really caught my eye and ear was the KD-CLN-LP200 ultrasonic record cleaner. I had just bought If 2 on vinyl. He played it uncleaned with a simple dry brushing. Then Barry cleaned my LP on the KD-CLN-LP200, the diff. was night and day. I want one in the worst way but with an MSRP of $3,995 it will not likely happen anytime soon.
http://transparentmusic.net/
http://klaudio.com/
Because I am The Pumpkinking
  • gce
    gce Posts: 2,158
    $3,995 :| man I could think of a lot of things to buy with that money!
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
    Pumpkin man.... Just call me your savior....
    If you can DIY and I think you can.....
    Hows about under 500 for the whole DIY ultrasonic kit lol...
    http://thecarversite.com/yetanotherforum/default.aspx?g=posts&t=15515
    2014-07-03T00:54:25.281Z-VIBRATO%206Q60KFDCH%20working01.JPG.855x570_q85_pad_rcrop.jpg
    https://www.tindie.com/products/VibratoLLC/6-quart-60khz-vibrato-ultrasonic-cleaner/
  • Jhayman
    Jhayman Posts: 1,548
    Looks Great, careful around the pets though, that's funny because I use my nitty gritty and my cats just sits at my feet while I use it even when I vacuum it..
  • pumpkinman
    pumpkinman Posts: 10,545
    Thank you Obi Wan I'll check it out. I just might give a DIY one at shot.
    P -man
  • schwarcw
    schwarcw Posts: 7,360
    I see these units becoming very affordable in the next several years. At the Chicago and Capitol Audiofest, they were selling one from Ultrasonic.com that cleans 6 or 10 lps at a time for $1,395. This one: http://www.ultrasonicrecords.com
    Carl
  • vmaxer
    vmaxer Posts: 5,124
    schwarcw wrote: »
    Looks good, maybe some day...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mikey081057
    Couldn't you just take something like this and modify it with a rotisserie type thing to spin the lp's while immersed ... Maybe not the most elegant but not $4G's.
    http://www.amazon.com/TruPower-UC-20D-Digital-Ultrasonic-Cleaner/dp/B002E1JPCM/ref=sr_1_9?s=industrial&ie=UTF8&qid=1410097773&sr=1-9&keywords=ultrasonic+cleaner
    Garage | Polk Monitor 5B's
  • Mikey081057
    This one might be better suited.
    http://www.amazon.com/dp/B00L9F37JQ?psc=1
  • vmaxer
    vmaxer Posts: 5,124
    That's a great idea, I think it could work.
    Thanks for the idea.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • gce
    gce Posts: 2,158
    There ya go. Had no idea after seeing all these over a grand record ultrasonic cleaners that you could get one this cheap. Then you get one of these and your under $500.
    http://www.amazon.com/Saber-Rotisserie-Motor-3-Burner-Grill/dp/B00BY9YL8I/ref=sr_1_4?s=appliances&ie=UTF8&qid=undefined&sr=1-4&keywords=rotisserie+motor
    Anaheim Hills CA,
  • vmaxer
    vmaxer Posts: 5,124
    gce wrote: »
    At some point I will try this. I've been traveling a lot for work lately and am behind on things around the house. Once this settles a bit I will look into this more.
    I do have a RCM now, but don't even have a turntable set up at the moment. I will get one back in before long though.
    I do have experience with a lot bigger ultrasonic cleaners and they work very well...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mikey081057
    Nice... Just set it up with shaft and mounting system where you can put multiple LP's at once...Don't want to see you put 4 more holes in your records... :D
  • oldmodman
    Can you get 20 guys to each kick in $200.00 per person. The cleaner would rotate among you so each person could clean all their records. Just make an allowance that if one guy had a "dirty platter emergency" he can drop by to clean his record out of turn.
    Also set up a deal where for X amount of cash records can be cleaned for "outsiders"
  • doctorcilantro
    Jhayman wrote: »
    This is the one I have. Works great. Still working on the rotor system.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
