Oppo 103D
Hey everyone
I'm about to purchase an Oppo. I was looking at it on Amazon, and there was a section that showed that other buyers also bought a calibration disc (Spears and Munsil) for another 30 bucks.
Is this recommended to buy this? I will have my TV calibrated at some point. Can a home theater installer just calibrate my tv and the Oppo without me having to buy a calibration disc?
Thanks.
Best Answers
  • BlueFox
    BlueFox Posts: 15,250
    Answer ✓
    You do not need the disk for calibration. A professional will have test equipment to do the calibration.
  • specd_out
    specd_out Posts: 504
    Answer ✓
    If its an ISF Certified Calibrator he will calibrate the tv first, then connect the oppo and run a dvd to double check that the player isnt changing the signal.
    I am ISF level II certified, and while calibrating a Sony xbr850b I checked the bluray after the tv was calibrated and the oppo 103 was crushing the blacks some. Slight adjustment on the brightness tab on the oppo and it was perfect.
    Thats the main issue with the dvd calibration disks. They are only as good as the settings on the player. If your settings on the player are off your calibration of the tv will be off. Granted its much better then not doing anything at all.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
Answers
